7 members (Ritchie B, Bitsobrits, Tony Quinn, IcePack, Rog G, DazMog, Image),
294
104
Topics49,868
Posts837,642
Posts: 22,366 Likes: 354
Posts: 22,366 Likes: 354 |
What about the electronic systems? Does this really work? https://www.catsystemsaustralia.com.au/
Posts: 1,705 Likes: 35
Posts: 1,705 Likes: 35 |
Roger 2011 Plus 4
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
Lastly I remember using sacrificial anodes in my Triumph Herald in the 60's......they were called the doors! Nick I thought that the Herald was one big sacrificial body, the engine always survived!
Posts: 3,825 Likes: 69
Posts: 3,825 Likes: 69 |
But Richard, stainless bolts fitted through aluminium? Peter, you're right about the Herald. In the end my bonnet was held together with fablon! Sadly my next, a 1959 Sunbeam Rapier, wasn't much better....... Nick
Posts: 37,433 Likes: 978
Posts: 37,433 Likes: 978 |
But Richard, stainless bolts fitted through aluminium? I've not had cause to strip one down as yet so have no idea what precautionary measures the factory has taken if any, I don't envisage them fitting a ptfe sleeve over the threads somehow.... A good question for anyone visiting the factory.
Posts: 2,050 Likes: 12
Sir S1'a'lot Talk Morgan Expert
Posts: 2,050 Likes: 12 |
Well.....I've just bought a truck load of ACF 50 It better be good...  Anyway....I'm going to spray it all over the chassis on my new Dodge Truck I have another car with the fine white pimples of corrosion on engine ancillaries ....question is will this stuff stop this from happening any more?
2002 Aero 8 S1 2023 Plus 4 (woman’s)
I've only had pimples of corrosion when the garage was damp. Come the dehumidifier this doesn't happen.
The "white pimples" seem to be caused by salty water drying on a warm engine and starting corrosion as they dry. The as soon as moisture arrives the salt crystals pull it out of the air and corrosion re-starts.
ACF 50 and a dehumidifier both help.
Does ACF 50 not wash off?
Does ACF 50 not wash off? Seemingly not...getting it of the garage floor requires a solvent!
