Morgan Aero 8
10 members (MartO, RedThree, +8Rich, High Hamster, jbk, RubyMog95, JohnHarris, James B W, RichardV6, Peter G3VNH), 303 guests, and 100 robots.
+8Rich 76
Topics49,869
Posts837,664
Moggo
Page 2 of 4 1 2 3 4
What about the electronic systems?
Does this really work?
https://www.catsystemsaustralia.com.au/
Rog Offline
Wouldn't it be nice if they did smile
http://corrosion-doctors.org/Car/car-electronic-rust.htm
Roger
Peter J Offline OP
Formerly known as Aldermog
Originally Posted By nick w
Lastly I remember using sacrificial anodes in my Triumph Herald in the 60's......they were called the doors!
Nick
I thought that the Herald was one big sacrificial body, the engine always survived!
But Richard, stainless bolts fitted through aluminium?
Peter, you're right about the Herald. In the end my bonnet was held together with fablon!
Sadly my next, a 1959 Sunbeam Rapier, wasn't much better.......
Nick
I've not had cause to strip one down as yet so have no idea what precautionary measures the factory has taken if any, I don't envisage them fitting a ptfe sleeve over the threads somehow.... somestick
A good question for anyone visiting the factory.
Sir S1'a'lot
Sir S1'a'lot
Well.....I've just bought a truck load of ACF 50
It better be good... confused2
Anyway....I'm going to spray it all over the chassis on my new Dodge Truck
I have another car with the fine white pimples of corrosion on engine ancillaries ....question is will this stuff stop this from happening any more?
2002 Aero 8 S1
2023 Plus 4 (woman’s)
I've only had pimples of corrosion when the garage was damp. Come the dehumidifier this doesn't happen.
Peter J Offline OP
The "white pimples" seem to be caused by salty water drying on a warm engine and starting corrosion as they dry. The as soon as moisture arrives the salt crystals pull it out of the air and corrosion re-starts.
ACF 50 and a dehumidifier both help.
Sir S1'a'lot
Sir S1'a'lot
Does ACF 50 not wash off?
2002 Aero 8 S1
Peter J Offline OP
Seemingly not...getting it of the garage floor requires a solvent!
Page 2 of 4 1 2 3 4
