Topics49,870
Posts837,669
OXR 5 L - Learner Plates On
Posts: 209 |
Hi Guys, Is there a simple, foolproof way of determining what type of fluid is in my braking system. The brakes were totally re-built some years ago and alas the PO who did the work cannot remember if he used silicone?.
Tony
!954 DHC
Posts: 1,947 |
This sounds about right to me but I can't properly link owing to the use of a borrowed iPad and stolen bandwith (remember boys and girls, bad men and Martyn will steal your bandwidth unless you password your wifi). http://www.belray.com/how-determine-what-brake-fluid-your-bike
Posts: 22,366 Likes: 354
Posts: 22,366 Likes: 354 |
I believe that silicon fluid has a purple hue.
Posts: 5,657 Likes: 4
Posts: 5,657 Likes: 4 |
Dave you are right it's a slight purple. When used, it's also normal to attach a warning label to the master cylinder.
Martin (Deano)
Posts: 6,958 Likes: 117
Posts: 6,958 Likes: 117 |
Dave you are right it's a slight purple. A sort of purple haze?
Posts: 209 |
Many Thanks folks, will check it out tomorrow.
Tony
Posts: 142 |
Drip some onto your wing and see if it does or doesn't eat off the paint!
Actually, you could drop some onto a painted surface I guess.
1960 Morgan +4 4 seater 1997 Nissan 240sx S14 2011 Nissan 370Z 2009 Triumph Street Triple
