2 members (DaveK, MOGDave), 256 guests, and 43 robots.
+8Rich 86
by stumog - 26/08/26 10:24 AM
Topics49,844
Posts837,360
Page 5 of 6 1 2 3 4 5 6
Originally Posted By DaveW
The steering effort is reduced considerably with bearings instead of damper blades, and anyone with damper blades due a kingpin change should do this at the same time.
True for the later rack & pinion cars, as they changed to castor angle to 6 degrees to create a bit more lead. With the earlier cars equipped with steering boxes the castor angle is only around 4 degrees. Steering is a lot lighter anyway with these cars, and removing the damper blades can cause unacceptable amounts of the dreaded St Malvern's Dance. Some people fit telescopic dampers instead, but I find the damper blade system works fine as it is.
Compared to an MGB it's surprising what a home mechanic can stll do. Apart from the basic settings of mixture, idle speed, timing - in other words the carbs and distributor settings - everything else is still fair game, so all lubrication, plugs, belts, tightening nuts & bolts, basic electrics and so on.
And there are still nipples on the propshaft.
But I accept that a significant proportion of buyers don't want that, but want 'plug & play', which at the moment a trad Morgan isn't.
You are quite right, and I grow increasingly annoyed at the effectiveness with which the canard that "one cannot work on modern cars" has been foisted on us by the trade. The fact of the matter is that with the correct tools working on one's own car is far easier than it used to be. Plug in the diagnostics, read the fault codes, look up the references, take the appropriate action.
It's sad that fewer and fewer people are interested in doing their own maintenance, quite apart from anything else it pushes the costs of ownership up.
I 'upgraded' my front end suspension (June -13) with the Suplex kit and fitted specially made Vesconite Hi-Lube bushings along with lip seals (Note: there is no 'moist absorbing problem' with the Hi-Lube plastic).
So far I have only praise for the whole 'system' and you can read my summary in the Comfort_suspension thread: http://www.talkmorgan.com/ubbthreads.php/topics/152134/17
Like many of you, I think that some sort of 'gaiter' is needed to protect the lower end of the king pin. I will sort that when it gets warmer...
I also would like to take the opportunity to thank those of you who guided and supported me when I needed advice. Without this forum and your input I'm not sure I would have dared - thank you all and have a nice Holiday and a Happy New Year.
:xmascheers:
-99 4/4, 1.8 Zetec, Indigo Blue, 2-seat, Suplex RS
-04 Citroen Pluriel, 1.6 Sensodrive, Met Orange
Well done Thomas! This solution should last you many tens of thousands of miles even without a lower gaiter.
Thanks Hamwich, I think so too and I'm really glad I finally got 'a round tuit' wink
Moggo Offline OP
viking
Best not to delay putting on the gaiters (unless she is off the road for the winter)...
Graham
Octogenarian - (82)
1.8 4/4 Ivory
ToyoYarris
VolvoV70
I appreciate your concern Moggo but she is well protected from the icy and salty conditions we have here in northern Sweden during winter. I will not wake her up until the bears have come out of their dens and the roads have been washed with a good spring rain. umbrella
Gents. Can anyone advise of a supplier for Vesconite Hilube bushes? Appreciated. Kevin
Hi Kevin,
Personally I have not come across a manufacturer of a "off the shelf" King Pin Bush in Vesconite Hilube. I think you will have instigate the manufacture of them yourself. If you do not have the facilities to undertake this yourself then you can approach any competent Precision Engineers who will able to produce them as they do not require any specialized tooling in the making them. I have made reference to this subject in a previous post
http://www.talkmorgan.com/ubbthreads.php/topics/218288/Re_Front_suspension_longevity#Post218288 The material itself you will have to obtain from Vesco as they seem to keep a tight control on its availability, but its website is very informative regarding the design of Bushes
Owen
"bilibib"
1982 4/4 Twin Cam, Royal Ivory
1932 Super Sports, Duo tone(two tone)Green
Thanks Owen,
hate to continue the questioning but you wouldn't know the ID/OD/length etc? Appreciated again.
Kevin
Kevin,
The normal Bronze Bush has a O/D of 1.233", a I/D of 1.000" and a length of 2.5". Now when it is fitted into the Stub Axle tube, which is a piece of standard seamless tubing whose bore is not round, has a nominal bore of 1.250" and after being welded into the casting is not straight. With the tube elliptical and bent it requires the Bushes to be Line Reamed to remedy the errors and achieve function. That is why I bored the tube out, as mentioned in the thread I referred to previously, so that when the Bushes are fitted they are aligned together with a resultant fit which does not require reaming, which I think is how Morgan's may have approached the issue when fitting their Devol Bushes,
In conclusion if you are prepared to have your Stub Axles bored out to a true 1.250" I will let you have a drawing of the Bushes I designed for this application
Owen
"bilibib"
