0 members (), 335 guests, and 37 robots.
+8Rich 101
John V6 63
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
Topics49,915
Posts838,214
MossyfromNZ
#244348 04/01/15 09:03 PM
Driving back from Bicester this afternoon and following a couple of Morgan's I appreciated how dim the standard rear lights are. I know the subject has been discussed before but can anyone let me know the actual LED bulbs that fit the rear lights and whether they cause any problems at MOT time, or any other time?
Andrew
'Alice' 2013 Duratec Plus 4. Pearl Blue
See www.autobulbsdirect.co.uk
LED tail light are strictly unlawful unless CE marked (not usually the case). However an MOT tester does not dismantle components so provided they are of the correct colour and brightness they will pass the MOT. My LED stop/tail lights are bright and a good colour - I am awaiting my first MOT with them but can see no earthly reason why they should not pass. I have also got LED indicator lights but this is a little more complicated as you may need to fit a special relay or fit ballast resistors depending on your car's wiring. PM me if you want more details.
There has been a lot of chat on the blog about this.
Do read this as I think it correctly sums up the legalities
FHBVC newsletter
In the real world, I have presented a car with LEDs for a MOT, but on mine, they are legal, yours isn't. But, the MOT tester does not take things to bits, so if he's not told - he won't know!
As a result, the sensible advice is fit ones you think are ok, to one side and compare with the other after dark. Don't just look directly behind, but also look at an angle. It is debatable whether LED brake lights are ever legal since some sources say the bulb wattage is specified and obviously, LEDs consume way less power. (But I have a defence as the car is pre 34...).
I have LEDs fitted on the wing lights, front and rear sidelights and brake lights. The centre high level light is also LED. The car passed the MOT in November with no comments.
Neil
Honda S2000
Lexus UX 250h
Toyota Auris Hybrid
NeilM #244407 05/01/15 09:20 AM
Drive on the Wild Side
Neil
+1 thumbs except cyclops light still to do, either led bulb or as you have done
Adrian
+1 except the side lights
