1 members (BHV),
265
43
Posts837,992
Posts: 157 |
My wee +4 has developed an issue with the lights: no indicators or headlights ( on either beam), sidelights are ok, hazards are ok. It seems to be the switch that's failed, is there any way I can test before I order a new unit? And any suggestions where I can get a replacement? Thanks in advance :-)
2011 +4 'LB' Indigo Blue, Heron trim Saab 9-3 1.8T Sportwagon
Posts: 970 Likes: 1
Posts: 970 Likes: 1 |
Check fuses/ relays first I can't help with which ones as my car is old and very different but fuses and relays are more likely than switch gear
Good Luck
Magwa 1950 Allis Chalmers B tractor 2000 Porsche boxster 2014 Skoda yeti 4x4 elegans
Posts: 3,383 Likes: 14
Posts: 3,383 Likes: 14 |
Mike
Worth a look at the small strip on the under bonnet bulkhead, drivers side on UK cars. I had an indicator failure on my 08 +4 and after checking all the under dash fuses I checked the under bonnet strip, more in hope than anything, sure enough one of those was blown and that's all it was. Why they would wire it this way is something known only to Marshians and MMC ;-)
Posts: 157 |
Seems pretty random that indicators and lights are common wired, I'll have a look in daylight, thanks
Seems pretty random that indicators and lights are common wired, I'll have a look in daylight, thanks Agreed but when did that stop MMC. Like taking a buzz bar feed of the back of one fuse box to feed another?
Posts: 2,583 |
A couple of years ago I had a problem with the sidelights - the switch was at fault on the steering column - the connectors had drooed out as they had not been put in properly - for once a Ford switch problem & not an MMC one. MMC sorted it on warranty.
Posts: 131 |
I had a similar problem which turned out to be the bullit connectors under the wing look to be straight out of 1960's mini and collect all the muck off the wheels.
Tony
Claret Red +4
