6 members (Black Adder, Hamwich, +8Rich, Bishmog, Joe Speetjens, lord-richfield), 310 guests, and 49 robots.
John V6 68
+8Rich 65
DaveW 64
9,208 Registered Users
by Soleng - 24/07/25 05:32 PM
MulFab and Petrol Tanks
by Rovert - 24/07/25 09:51 AM
Maybe an MX5
by howard - 23/07/25 04:10 PM
Dashboard Turn Signal Light
Ozzy Osbourne
Topics48,347
Posts813,062
Captain Morgan, IRWIN
Page 35 of 41 1 2 33 34 35 36 37 40 41
Update 47 - Fitting the bonnets and sorting out a few other things
Now we're pretty much finished under the bonnet lets get those beautiful bonnets fitted. First off we need to fit the cowl and work from there.
So, out with the cowl lets get that fitted....
Nice new beading rubbers and also fabric tape - looks smart in the contrasting white and blue.
We can now fit the grill in place.
With the hinge brackets sorted, its out with the bonnets for fitting...
Check out the louvre's on those!!
However - not so easy - whilst some of the bonnet catches are easy to fit the custom nature of the bonnets make the others a bit more complicated... so a lot of fiddling, bending and tweaking to get them to work with the new positioning.
A relatively small job but this took most of the day - on and off.. the small details eat time.
All the catches fitted and working smoothly
So there you have the bonnets fitted.....
Next up is some of the interior things - the trans/prop tunnels finish from the factory were not great - these were sent along with the roof bars to be shot blasted and powder coated satin black. We can then decide what of this is fitted with leather cover or just raw. I suspect the prop tunnel can be fitted raw and possibly make some smart partial covers for the gearbox cover....
So taking the roof bars and assembling them onto the tensioners and popping them into the car we have the frame... looking better than new given the quality of paint used originally.
Its coming along nicely....
Some interior electrical's left to do, seats in and doors to be assembled and fitted.
Ooooohhh then it's ready to go to have its first start and ECU tuned.
Fantastic feedback/report!
What an amazing detailed project...thanks for posting all these updates!
Neil
the opening is to evacuate the hot air?
Don't Worry, Be Happy
Morgan 4/4 1985 2,0 Zetec
BMW R1200 GS
Triumph TR140
Great read as ever.
Great to see progress
2025 MG ZS EV aka Trigger
Which one? on the bonnet (the scoop) - that's the intake which allows the air filter and intake manifold to extend over the wing SS style.
Its been an interesting journey - having been hands on with almost every part of the two cars and much being custom fabrication of one sort or another.... it makes one hell of a build record!
on the end of the bonnet is there not a opening to evacuate more hot air as usual?
BMW R1200 GS
Triumph TR140
[b]Update 48 - Final ECU electricals, Trans tunnel, door jams, dash pad and seats[b]
Having mounted the Omex 600 there were a couple of things that were outstanding. Firstly there is the 12v relay feed to power the injectors and also the connection of the injector pump control line from the ECU to the fuel pump. This enables the ECU to auto prime the fuel system as long as the emergency fuel switch is thrown.
Both 12v feeds we felt needed to be fused - coming off the master electrical switch (the red key). Its always good to label things so you know what they are later.
Making up the wiring feeds to power up the relays
Sorting out the relay bracket
A couple of hrs later all the wiring is in and its time to be tested.
This is the first time the electricals have been fired up in two years and we've made a lot of changes. So we flip the master switch and twist the key... nothing... !! Doh!
We realise that the relays are diode relays and may not be powered up given the feed direction. We flip the wires and boom! On twist of the key, the pumps fire up for two seconds and go silent as needed. The DL1 fires up and the Dash comes on a reads out the relevant sensor info. Fantastic, electricals work.
Door jam
The original aluminium door jam finishes were toast and are not available any more. So what to do... the aluminium ones didn't last so well so we decided to look at a stainless steel option. We sorted out some thin stainless and had it put through a brush effect finisher. Following a lot of cutting, bending and fettling we managed to get them fitted to both sides. We used beading rubber to provide a finisher for the inside edge and help with draft exclusion.
Fitting the trans tunnel
Having had the trans tunnel powder coated it needs to be fitted.. we did some preliminary fitting to make adjustments for the 6mm drop due to the use of Aluminium for the floor rather than plywood sheet.
The remaining adjustments that needed to be made was related to the bulkhead holes. These were obviously too high up now so there was a bit of trial fitting and drilling required.
The transmission tunnel fits nicely and looks smart in black.
Dash Pad
I'm keen to keep the dash pads in both cars so having stripped away the white leather it will be re-covered. However there are some adjustments to the pad to help the fitment when it gets all put back together. You can see in this shot, we've cut out the holes for where the Brooklands screen mounts go, I've drilled out the original self tapper holes and put advils in. I've sourced suitable stainless Philips screw head bolts to match up to the screen mounts.
The dash pad all lines up with a bit of manipulation.
The seats
Finally there are the seats... when we originally built this car Sparco were unable to supply a second set of pro alloy mounts so we ended up fabricating a suitable set of mounts to deal with the constraining factors of a Morgan.
Sparco still make the mounts but they are a slightly different size and design. The overall concept is the same just not quite in several ways.
With a bit of compare and contrast you can see the comparisons from the original brackets and the new style.
Personally I prefer the originals however these will also work.
This is not quite final fit but its getting there
Wing brackets
Finally the wing brackets, we have the originals of these however having stainless bar of a suitable size on the shelf we quickly fabricated new ones, these will probably outlive the car.
We've also sorted all the rear lights electricals, the horn and the cooling fan otter switch (we did have a choice for the ECU to control this on the Omex 600 but the 200 does not have this function so otters all round to keep things simple).
Great to read as ever!
