1 members (Ian B), 337 guests, and 108 robots.
+8Rich 76
DaveW 52
Topics49,867
Posts837,614
That dash looks stunning
Lifts the interior to a whole new level
Top work and top results - thanks for sharing.
+1
Martin (Deano)
Lovely Dash, Torsten. Congratulations on all your good work. What is t he red button on the dash? Is it a start button ?
David
Morgan Plus 4 2005
Jaguar XJ8 1999
LR 110 Station Wagon 2008
Volvo V90 D4 2017
The words "Engine Start" may be a clue? somestick
Not sure if it is the same with your engine - but the air filter cover on my 4/4 sport banged on the cross member above it - about 1/8" clearance - sounded like the suspension was bottoming out - but sound transmitted through the wings - a bit of rubber tubing fixed it - worth a check.
ini Offline OP
DaveW is right, the red button is the start switch. I bought it second hand at the Schloss Dyke Event because I like it so much.I did this switch in parallel to the exsisting steering wheel lock so that I can use both now. The switch near by is for the additional spot lights.
Thanks for all your positiv postings.
Torsten
Torsten
plus 4 MY 2014
