Topics49,866
Posts837,588
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
That dash looks stunning
Lifts the interior to a whole new level
Posts: 5,657 Likes: 4
Posts: 5,657 Likes: 4 |
Top work and top results - thanks for sharing. +1
Martin (Deano)
Posts: 77 |
Lovely Dash, Torsten. Congratulations on all your good work. What is t he red button on the dash? Is it a start button ?
David Morgan Plus 4 2005 Jaguar XJ8 1999 LR 110 Station Wagon 2008 Volvo V90 D4 2017
Posts: 22,364 Likes: 353
Posts: 22,364 Likes: 353 |
The words "Engine Start" may be a clue?
Posts: 2,583 |
Not sure if it is the same with your engine - but the air filter cover on my 4/4 sport banged on the cross member above it - about 1/8" clearance - sounded like the suspension was bottoming out - but sound transmitted through the wings - a bit of rubber tubing fixed it - worth a check.
Posts: 163 |
DaveW is right, the red button is the start switch. I bought it second hand at the Schloss Dyke Event because I like it so much.I did this switch in parallel to the exsisting steering wheel lock so that I can use both now. The switch near by is for the additional spot lights.
Thanks for all your positiv postings.
Torsten
Torsten
plus 4 MY 2014
