6 members (Sir Percival, B3MOG, CLPlusFour, Alan Patterson, Paul F, Hamwich), 321 guests, and 40 robots.
+8Rich 64
Adam12 62
John V6 58
9,215 Registered Users
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Pur Sang Type 35
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,364
Posts813,336
Members9,215
Is this any help?
www.harleycustom.co.uk/UK_Custom-Dynamic..._384_1972_15248
Usual disclaimer that I have no connection with the website etc....
Originally Posted By N22MOG
Eddie, sorry if I've confused. When I switched the wires the LED came on with the running lights but doesn't get any brighter when the brake is applied.
Are you expecting the light "to get brighter"? Because that is not how a tail/stop lamp works. You should have two positive cables (and one ground). The first will be connected to the side light feed and will drive the standard brightness LEDs, as a tail lamp. The second will be connected to the brake light feed and will turn on the higher brightness LEDs as a brake light.
I used a Landrover replacement dual brightness LED tail/stop lamp unit which is a straight swap for the Cobra high level brake light. As I only needed the bright brake light, I didn't connect the standard brightness cable. But it was easy enough to check the function of the two separate circuits to determine which was which.
Nigel
I think Steve is saying that one set of LEDs works, the other doesn't...
'09 Gen2 MINI Cooper ragtop
Nigel
Nigel can you pm me the details please
2025 MG ZS EV aka Trigger
[/quote]
Nigel [/quote]
There are two positive leads, both connected to the existing Mog lights. I'm not expecting the LEDs to get brighter and assume that there are two rows of LEDs but I can't see if there are through the red lens when it's unlit. I need to get SWMBO or someone to depress the brake pedal whilst I look at the light (because I'm too lazy to uninstall it to test it). I'm not too unhappy at the moment because it works really well as a brake light, which was the purpose of fitting it.
Steve L.
1996 Plus 8
N22 MOG
John - the thread on replacing the Cobra with a LED is here:
http://www.talkmorgan.com/ubbthreads.php/topics/202700/1
And the lamp units can be bought here (also available in red):
http://www.ebay.co.uk/itm/RDX-LED-CLEAR-...=item35cf271cd9
