0 members (), 328 guests, and 25 robots.
+8Rich 95
John V6 52
Topics49,897
Posts838,017
#249359 27/01/15 04:33 PM
WOX9 Offline OP
Probably a daft question with an easy answer..... How do you remove the mirror and stem from the door bracket on a new Morgan, I thought it just pulled out but doesn't seem to. Loosens off slides up and down, but wont come out - Help...
+4 Jaguar Lazuli Blue - MO6 4 MOG, Morgan Clubsport.
Laser Stratos (sadly sold)
WOX9 #249360 27/01/15 04:34 PM
I assume that you've loosened the setscrew. The end of the stem gets stuck under the plastic cap, so needs a bit of persuasion.
WOX9 #249374 27/01/15 05:44 PM
Hi,
Your footnote suggests Morgan don't sell cars direct anymore, when did this happen? Will keep dealers happy I suppose..
Thanks,
Will
WOX9 #249416 27/01/15 08:30 PM
I think that when I swapped my mirrors I took the plastic cap off to get the stem out. This needs doing carefully to avoid putting pressure on the mirror mount and door, but isn't too difficult.
When putting the new mirror stem back in ensure the cap refits so the cutaway is in the right place for the stem screw to go through.
Once I figured out what to do it took about 5 minutes per side.
Adrian B
Green 4/4
WOX9 #249419 27/01/15 08:39 PM
There is a plastic "circlip" on the end of the mirror shaft that stops the full extraction of the mirror. This is in addition to the plastic conical "washer" you can see at the end of the stem - it is easier if you slide this up the shaft before trying to pull the standard mirror out. I removed the stem screws completely. More force required - but not so much that you damage the base or door. Once you have done the first one you will be happier.
Good luck.
Costock, UK
Disco 5
WOX9 #249422 27/01/15 09:01 PM
Woxie.....shame on you, you should know the answer to that innocent
Take care not to damage the plastic "grommet".....they are hard to get hold of!
WOX9 #249426 27/01/15 09:13 PM
WD40 helps
I had the same problem and removed the screw and sprayed WD40 into the grommet area. Mirror came straight out
Good Luck thumbs
Magwa
1950 Allis Chalmers B tractor
2000 Porsche boxster
2014 Skoda yeti 4x4 elegans
WOX9 #249482 28/01/15 10:08 AM
WOX9 Offline OP
All makes sense now, tks all, on my old Morgan they just popped out - cant afford to scratch the new one!!
WOX9 #250469 02/02/15 05:19 PM
WOX9 Offline OP
Problem solved, simple really, its winter, its cold, as soon as I warmed up the metal part a little, all popped out - easy!!
