8 members (High Hamster, CLPlusFour, Arwyn Williams, RedThree, MartinB60, A11OGE, BobtheTrain, DavidR), 275 guests, and 42 robots.
+8Rich 64
Adam12 62
John V6 58
9,215 Registered Users
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Pur Sang Type 35
Tom Lehrer RIP
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,362
Posts813,320
Members9,215
Ray Offline
Not sad , EROTIC to some. sorry to most. petolheads.
Originally Posted By MDH
Matty - what percentage was the fuel guage reading when the motor died?
Most likely 0% for many many miles innocent
Hannes
once: Green M3W; 2013
now: Red 4/4 Sport; 2011
Originally Posted By David G
Hi Martyn,
I Presume you mix a drop of CasTrol R to produce the real aroma of the 30s.I still race all the classic bikes on Castrol R but as you say not much gets passed modern oil control rings.
David
Actually no to Castrol R. For the smell you can't beat it, but oil sold as two stroke oil is both designed to lubricate and be burnt in petrol. So I just use whatever is cheap!
Does anyone still use Redex upper cylinder lubricant?
Matty Offline OP
Well this is the weird thing. As the fuel gauge is so crap, I use the trip meter. The gauge was reading 0 but had only been doing so for 50 miles or so. The trip meter from what I thought was a full tank was reading 200. I must have reset the trip at some point and forgot I'd done it. Senility creeping in. Generally I do fill up as soon as I hit zero, knowing I should at least have 100 miles spare capacity.
I'm also gonna invest in a mini jerrycan of some sort.
At one piont the guy was muttering about, hoping his apprentice had been storing break cleaner in the can also.
It ran fine after adding new fuel so I'm going to take the old girl for a blast today and hope for the best!!!!
Matty Offline OP
Good advice
Originally Posted By Matty
Good advice
Another good advice: get the proper VDO fuel level cylinder in 280mm length.
Costs some £50,- and takes few minutes for exchange. You can do it yourself.
The 240 mm cylinder is compltely useless. It's such a shame Morgan supplies the TW with the wrong unit.
Example: ( but you need 54??mm diameter / have to check )
https://www.merlinmotorsport.co.uk/p/vdo-dip-type-fuel-sender-280mm-long-224011000280g
Hannes
I am just reading the OHB for my newly arrived 2014, and it says fuel capacity 25 liters at "E" (0%) + there is a maximum of 15 liters remaining.
They must have an overstock of short gauges.
Stig
Good advice!
I fitted the 280mm sender to my car...an easy fix and v v worthwhile!
Neil
I'm told by an oil company chemist I know, that my use of two stroke oil is both cheaper and better.
No idea why Morgan sell the 5 speeder with what is really the wrong gauge unit. I did for a couple of years have a Rover 214 and that had a 12 gallon tank. 12 showed full, 8 showed half full (you can see where this is going can't you) and 4 gallons remaining showed empty. An easy 140 miles could be driven at speed, but you'd give up and fill up before going that far!
