0 members (),
251
60
Topics49,861
Posts837,540
Posts: 16 |
Car was starting fine then....water pump leak sprayed af around adjacent area. Still started then not so much.
Need to fix pump but what is best way to get spark back. Engine spins fine but was fire. Check dist rotor and seemed dry. Plus seem dry. Would antifreeze on coil be a problem? Any thoughts or comments appreciated. Tahnks
71 Plus8 Yellow/Blk 57 Morris Minor Trvlr 1098cc 93 MB 500E 66 MB 230SL 48 Chev Fleetmaster Conv LS1
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
Clean all electric contacts including the points incase something has coated them. Try some thing like white spirit,
Posts: 22,362 Likes: 353
Posts: 22,362 Likes: 353 |
Check HT leads - make sure no water trapped in the ends, especially on coil to distributor lead.
Posts: 16 |
Thanks Time to go to work.
Posts: 27,813 Likes: 749
Posts: 27,813 Likes: 749 |
Then spray with damp start
