6 members (DickJ, Mats, DCH, ChrisConvertible, Burgundymog, BobtheTrain), 154 guests, and 71 robots.
+8Rich 76
Topics49,863
Posts837,548
gcarguy Offline OP
Car was starting fine then....water pump leak sprayed af around adjacent area. Still started then not so much.
Need to fix pump but what is best way to get spark back. Engine spins fine but was fire. Check dist rotor and seemed dry. Plus seem dry. Would antifreeze on coil be a problem?
Any thoughts or comments appreciated. Tahnks
71 Plus8 Yellow/Blk
57 Morris Minor Trvlr 1098cc
93 MB 500E
66 MB 230SL
48 Chev Fleetmaster Conv LS1
Ray Offline
Clean all electric contacts including the points incase something has coated them. Try some thing like white spirit,
Check HT leads - make sure no water trapped in the ends, especially on coil to distributor lead.
gcarguy Offline OP
Thanks Time to go to work.
71 Plus8 Yellow/Blk
93 MB 500E
66 MB 230SL
Then spray with damp start
