1 members (yobtaf),
370
95
Topics49,867
Posts837,614
Posts: 1,597 |
The 2001 Silver Road/Racing Aero MK 1 recently for sale with BHM was advertised with 60k miles. I saw this car when it was sold up in Scotland with Russel Patterson in 2009 and although it was stripped for racing, was road legal. Not sure how it got so many miles up, must have been more a road car than a racer because that's a lot of trips round a track.
Posts: 7,363 |
Quick correction - my Aeromax had done only around 25k miles total  I've done more than 50k miles in Aetos, but spread across 4 cars. S1,s2,s4,Aeromax... Figure shooter will have the highest mileage here on a single car.. Look forward to hearing Shooter's mileage, which as you say must be the highest in one car by some distance; at least on TM.  I've done about 75k miles in five different Aero's - S1, S2, S3, AeroMax, Aero SS. Let's wait and see the new car at Geneva, as it would be nice to break 100K!
Brian
1970 Morgan Plus 8 - Moss Box (Indigo Blue) 2014 Morgan SP1 (Rocket Red) 2015 Morgan Plus 8 (Rocket Blue)
Posts: 4,896 |
Quick correction - my Aeromax had done only around 25k miles total  I've done more than 50k miles in Aetos, but spread across 4 cars. S1,s2,s4,Aeromax... Figure shooter will have the highest mileage here on a single car.. Look forward to hearing Shooter's mileage, which as you say must be the highest in one car by some distance; at least on TM.  I've done about 75k miles in five different Aero's - S1, S2, S3, AeroMax, Aero SS. Let's wait and see the new car at Geneva, as it would be nice to break 100K! When considering highest mileage, I think that is a tricky one as I know that Morgan odometers are not necessarily that accurate, and can measure high or low depending on calibration, and that includes the newer cars taking miles meter readings from a sensor on the rear of the gearbox and then multiplying that by a factor to get the turns per mile at the wheel. If it's not set up right the inaccuracy can be quite large. Cheers
Adrian
Posts: 782 |
Yes - my Aero over-reads and the mileometer is out by about 10% compared with several 'normal' cars I do the the same run in.
So my mileage is actually lower than it shows by 10%. Can't remember but about 17,500 on a 2007 car so not enough. The M3W has done 4,100 in just over 2 years so that's a part excuse.
It's nice though when passengers think we're doing 90 and we're only doing about 80...
Posts: 2,433 Likes: 66
Posts: 2,433 Likes: 66 |
We drive the Aero on sunny days if we can but that wont really stop us we have done about 25k in four years mostly days out,. we also did about 20k when we had the plus four which included trips to france and spain.Nine years of magic Morgan motoring it was worth the wait.
Posts: 7,363 |
Cheers Interesting, I always wondered why most of our Aero speedo's were not very accurate, the Aero SS read about 10% fast when checked against a GPS
Brian
Posts: 782 |
I can't be bothered to look but am fairly sure there's a way of reprogramming the speedometer if you want to, and that it's covered somewhere in TM. Why Morgan don't make the speedos more accurate is one of the many Morgan questions of philosophical interest that keeps the mystery alive!
Posts: 14,009 |
There certainly is a way of reprogramming the Smiths speedos on the 4/4 and Duratec engined Plus4 using the trip button. I did it after fitting a competition back axle on my 4/4 Sport. The only problem is....I've forgotten where I found the instructions!
Posts: 4,896 |
Cheers Interesting, I always wondered why most of our Aero speedo's were not very accurate, the Aero SS read about 10% fast when checked against a GPS Hi Brian On the more modern Morgans I believe its down to the ECU programming and obviously the tyre size, and rear axle ratio (number of revolutions of the prop per revolution of the wheel). So there are several variables and presumably this is why any inaccuracy can occur if the ECU is or cannot be adjusted to reflect this.
Adrian
Posts: 2,050 Likes: 12
Sir S1'a'lot Talk Morgan Expert
Posts: 2,050 Likes: 12 |
Yes it's easy to reprogram your speedo.
Mine was 10% over but I've got it spot on now
Talk to your Mog Dealer
2002 Aero 8 S1 2023 Plus 4 (woman’s)
