0 members (),
220
87
Topics49,847
Posts837,389
Posts: 1,016 Likes: 2
Posts: 1,016 Likes: 2 |
Good report Charles. I am 99% sure that the pictures I've seen use stock headers and still use 2.5" OD pipework throughout, so there should be no change in the clearances anywhere at the front of the car. Is it not just the silencer section that is (necessarily) bigger section?
I hope to see it for myself on Sunday though.
Posts: 522 Likes: 1
Posts: 522 Likes: 1 |
I hope to see it for myself on Sunday though. Yes that is correct, the header is normal for minimal changeover hassle. However, a wider silencer requires a slight offset as you will see on sunday otherwise it will interfere with the body and not fit in-line on the two mounts. The offset is between the cat and silencer and part of the new package.
Posts: 522 Likes: 1
Note that 16hp increase isnt really fair as that is just the peak comparision. If you look at the whole graph characteristic you will note that for much of the rev range it is greater than a 16hp improvement.
Posts: 522 Likes: 1
Posts: 5,017 Likes: 3
Posts: 5,017 Likes: 3 |
Did not change my mind: ordered!
Posts: 1,213 |
Thanks for volunteering to test it Charles ! It'll be very interesting to hear your findings , any idea of delivery times ? As Calum has mentioned I too would be interested to know how loud they are as I also think the factory sports one is a bit much . Coincidently I'm in the middle of a house move , which has prevented me using mine much lately and makes me slightly hesitant about ordering one , but I might be persuaded ....
Hugh
Hugh
Posts: 3,732 Likes: 79
Posts: 3,732 Likes: 79 |
Well done Chsrles and The Austrian. Looking forward to your feedback on how easy (or not?) to fit and your thoughts. If you give the  will be joining you
Red Leader
Posts: 2,822 Likes: 155
Posts: 2,822 Likes: 155 |
Well done Chsrles and The Austrian. Looking forward to your feedback on how easy (or not?) to fit and your thoughts. If you give the  will be joining you +1 If I was stuck at home with a glass or two of something interesting I would likely have ordered a kit too! Sadly I am stuck in the middle of the North Sea for another ten days so will wait with baited breath for news of the fitting and effects of the kit.
Posts: 2,361 |
I can safely say you will all be very impressed
Instagram - WilliamsMotorsportuk - Lawrie Mills(Chunkylozza) Youtube - ChunkyLozza
Posts: 6,723 Likes: 2
Posts: 6,723 Likes: 2 |
Ok, we need a spaniel emoticon now..
