0 members (), 197 guests, and 89 robots.
Topics49,847
Posts837,389
DazMog, The Impaler, tlchzj79
Page 3 of 13 1 2 3 4 5 12 13
charlestkirby #254397 20/02/15 05:55 PM
Good report Charles. I am 99% sure that the pictures I've seen use stock headers and still use 2.5" OD pipework throughout, so there should be no change in the clearances anywhere at the front of the car. Is it not just the silencer section that is (necessarily) bigger section?
I hope to see it for myself on Sunday though.
R1NGA #254398 20/02/15 06:00 PM
Yes that is correct, the header is normal for minimal changeover hassle.
However, a wider silencer requires a slight offset as you will see on sunday otherwise it will interfere with the body and not fit in-line on the two mounts.
The offset is between the cat and silencer and part of the new package.
geof569 #254403 20/02/15 06:18 PM
Note that 16hp increase isnt really fair as that is just the peak comparision. If you look at the whole graph characteristic you will note that for much of the rev range it is greater than a 16hp improvement.
geof569 #254412 20/02/15 06:38 PM
Changed my mind. Ordered
geof569 #254422 20/02/15 07:48 PM
Did not change my mind: ordered!
Hannes
once: Green M3W; 2013
now: Red 4/4 Sport; 2011
geof569 #254423 20/02/15 08:00 PM
HJP Offline
Thanks for volunteering to test it Charles ! It'll be very interesting to hear your findings , any idea of delivery times ?
As Calum has mentioned I too would be interested to know how loud they are as I also think the factory sports one is a bit much .
Coincidently I'm in the middle of a house move , which has prevented me using mine much lately and makes me slightly hesitant about ordering one , but I might be persuaded ....
Hugh
Hugh
HJP #254442 20/02/15 08:50 PM
Well done Chsrles and The Austrian.
Looking forward to your feedback on how easy (or not?) to fit and your thoughts.
If you give the thumbs will be joining you smile
Red Leader drive
Chris99 #254445 20/02/15 08:58 PM
+1
If I was stuck at home with a glass or two of something interesting I would likely have ordered a kit too! Sadly I am stuck in the middle of the North Sea for another ten days so will wait with baited breath for news of the fitting and effects of the kit.
geof569 #254448 20/02/15 09:23 PM
I can safely say you will all be very impressed
- Lawrie Mills(Chunkylozza)
Youtube - ChunkyLozza
geof569 #254468 20/02/15 10:22 PM
SBM Offline
Ok, we need a spaniel emoticon now..
