0 members (), 141 guests, and 41 robots.
John V6 63
My Goodwood Revival 2026
Clutch for a 1982 4/4
DVLA frustration.
Old Book
by Pundit - 21/09/26 01:39 PM
First Morgan as it is now
by Strathaven, September 15
Topics49,940
Posts838,603
Mike123 Offline OP
Hi All,
I am sitting in the UK with our Plus 4 and a good network of dealers and knowledgeable Talk Morgan members to offer advice and assistance. Unfortunately a friend of mine in South Africa (Western Cape) is not so lucky from the point of view of support so any advice on this subject would be helpful.
He has a Roadster which is a 2006 model with the Ford 3.0L V6 motor.
He suffered from the engine just cutting out on him. It would restart but not keep running without some ‘quick start’ sprayed into the air filter inlet.
He noticed that there wasn’t the usual buzzing coming from the fuel pump. As far as could be tested in the car, the pump had an electrical feed.
The pump has been removed from the car by a mechanic and bench tested. When tested on the bench, pumping fuel, it delivers a good flow for about 3 seconds and then the flow drops to a trickle, but the pump continues to run and make the normal noise.
He needs to know whether this means that the pump is defective or whether it goes into a safety mode when it does not find resistance to flow. Any ideas here please?
If the pump is defective, he needs to know which other vehicle uses this pump. Any suggestions please?
I will be enquiring via our Mog Dealer in the UK about the fuel pump as well in terms of price, availability etc. Should a faulty pump be the outcome of the deliberation and diagnosis then it would be much easier to source a pump in South Africa, if possible, rather than importing one from the UK.
Thanks for your assistance.
Mike Lynch (on behalf of Peter Dimaio in SA)
How many feeds does the pump have just two? or power and additional wiring to say engine is running?
Fuel pumps normally Prime the system on turning on the car power and then stop and only start pumping for real once the engine is running but that is normally governed by the car electronics not at the pump itself?
Mark - No Longer driving
Mike123 Offline OP
Thanks John
Mike
The first thing to do is change the fuel pump relay. They are known to cause all sorts of problems, so a new one is a good start.
Honda S2000
Lexus UX 250h
Toyota Auris Hybrid
Drive on the Wild Side
+1, and some pumps do not like being run dry.
Adrian
It did the same on the bench though?
