Old Book
Topics49,940
Posts838,604
Posts: 5 |
Hi All, I am sitting in the UK with our Plus 4 and a good network of dealers and knowledgeable Talk Morgan members to offer advice and assistance. Unfortunately a friend of mine in South Africa (Western Cape) is not so lucky from the point of view of support so any advice on this subject would be helpful. He has a Roadster which is a 2006 model with the Ford 3.0L V6 motor.
He suffered from the engine just cutting out on him. It would restart but not keep running without some ‘quick start’ sprayed into the air filter inlet. He noticed that there wasn’t the usual buzzing coming from the fuel pump. As far as could be tested in the car, the pump had an electrical feed. The pump has been removed from the car by a mechanic and bench tested. When tested on the bench, pumping fuel, it delivers a good flow for about 3 seconds and then the flow drops to a trickle, but the pump continues to run and make the normal noise.
He needs to know whether this means that the pump is defective or whether it goes into a safety mode when it does not find resistance to flow. Any ideas here please?
If the pump is defective, he needs to know which other vehicle uses this pump. Any suggestions please? I will be enquiring via our Mog Dealer in the UK about the fuel pump as well in terms of price, availability etc. Should a faulty pump be the outcome of the deliberation and diagnosis then it would be much easier to source a pump in South Africa, if possible, rather than importing one from the UK.
Thanks for your assistance. Mike Lynch (on behalf of Peter Dimaio in SA)
Posts: 27,864 Likes: 775
Posts: 27,864 Likes: 775 |
Posts: 3,550 Likes: 5
Posts: 3,550 Likes: 5 |
How many feeds does the pump have just two? or power and additional wiring to say engine is running?
Fuel pumps normally Prime the system on turning on the car power and then stop and only start pumping for real once the engine is running but that is normally governed by the car electronics not at the pump itself?
Posts: 5 |
Posts: 859 Likes: 1
Posts: 859 Likes: 1 |
The first thing to do is change the fuel pump relay. They are known to cause all sorts of problems, so a new one is a good start.
Honda S2000 Lexus UX 250h Toyota Auris Hybrid
Posts: 4,896 |
The first thing to do is change the fuel pump relay. They are known to cause all sorts of problems, so a new one is a good start. +1, and some pumps do not like being run dry.
Adrian
It did the same on the bench though?
