Posts837,277
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
Thanks for all your comments - decided to go with the Toyo T1Rs, mainly as these are fitted to our hill climb car and seem to be good in the wet.
Neil Hopefully you will not get any induced steering wobble when you get up to speed. I would rather have wobbly wheels than have to drive in limp mode. Careful what you fill up with... Too much ethanol is reputed to put you into limp mode... No that's alcohol.
Posts: 6,954 Likes: 115
Posts: 6,954 Likes: 115 |
Ethanol, also commonly called alcohol, spirits, ethyl alcohol, and drinking alcohol, is the principal type of alcohol found in alcoholic beverages, produced by the fermentation of sugars by yeasts. It is a neurotoxic psychoactive drug and one of the oldest recreational drugs used by humans. It can cause alcohol intoxication when consumed in sufficient quantity. Ethanol is used as a solvent, an antiseptic, a fuel and the active fluid in modern (post-mercury) thermometers (since it has a low freezing point). It is a volatile, flammable, colourless liquid with a strong chemical odor. Its structural formula CH3CH2OH, is often abbreviated as C2H5OH, C2H6O or EtOH.
Cool head Bob it was only a joke.
I know. I cheated - almost straight out of Wiki.
Posts: 14,748 Likes: 158
Posts: 14,748 Likes: 158 |
Too much alcohol put me in permanent limp mode. The other bloke who turned in front of my motorbike had more than 3 times the limit. Better part of a year in hospital and rehab, and a hip replacement later...........
Sorry to hear that Peter Very hard to get through to some people.
Posts: 859 Likes: 1
Posts: 859 Likes: 1 |
My new set of tyres are due to be fitted tomorrow. I had a call from Blackcircle tyres based in Scotland, saying they had discovered that the Toyo T1Rs were dated from 2011 and this is certainly not good enough for such an important car as a Morgan ( their words not mine). They had sourced brand new tyres and were being rushed to Exeter tonight and will be ready for fitting at the agreed time of 10.30 hrs. They will ring first thing in the morning to confirm all is well. Now that is what I call service. Well done Blackcircle.
Honda S2000 Lexus UX 250h Toyota Auris Hybrid
Posts: 4,896 |
a set of sticky ones then, good news
Adrian
Posts: 14,009 |
I've used Blackcircle a few times now and have been very pleased with their service.
