7 members (Ritchie B, Bitsobrits, Tony Quinn, IcePack, Rog G, DazMog, Image),
294
104
Topics49,868
Posts837,642
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
I'm just buying a replacement air filter for my filter box to hopefully get a bit more air flow and increase the noise on my new sports exhaust and manifold
I've got a K&N code of E-2360 and the equivalent ITG of BH 114
From digging around, I've found out that the air intake box is likely from a 1999 Rover 825 and many more Rovers before it
Anyone had any experience with either and/or any mods to the air intake that doesn't induct hot air from around the engine but is easy to do to get more clean air through?
Posts: 27,816 Likes: 749
Posts: 27,816 Likes: 749 |
The Rover box as fitted to a +4 with the T16 engine had a flexible hose towards the front of the car.
I fitted the K&N
I fitted the K&N sounds the same as mine - the flexible hose inlet is fixed to the side of the inner wing just forward of the front bonnet catch Has anyone fitted a funnel type air duct to the front of the hose to scoop a bit more air?
Posts: 8,015 Likes: 1
Posts: 8,015 Likes: 1 |
Have you got the K&N filter oil .
Have you got the K&N filter oil . No - what does that do?
Oils the filter to trap the dirt. They come pre oiled & don't need redoing for a long time
You forgot sprays all over the underside of the bonnet .
Not if it is inside the standard filter housing it doesn't
Weber twin DCNF down draught 40S on mine sprays like hell .
Posts: 36 |
Hello, I suggest you to remove the air filter box and replace it with an open air system from K&N. I fitted this system on my 2009 4/4 Sport ad it works well. If you want I will send you some pictures D'Herde Bart
