8 members (B3MOG, Scrambledsignals, t50, Ulfulf, TBM, JohnHarris, linklaw, brownbaker), 371 guests, and 41 robots.
Adam12 70
+8Rich 69
John V6 52
9,215 Registered Users
Latest toy…
by Grumpy2 - 03/08/25 08:06 AM
Folding Reclining Seat Knob
Goodwood Speedmog 2d august
by Nick55 - 01/08/25 09:09 PM
Walnut Dashboard
by +8Rich - 01/08/25 06:24 PM
SORN
Morgan plus Four 2025
by Jérôme, August 2
Pedal mod
Pedal mod
by RibbleAdventures, July 31
4/4 80 Anniversary Rex_Tulips
by Rex_tulips, July 31
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
Topics48,376
Posts813,550
Members9,215
hugo Offline OP
I have found the offending wire causing the short , it was trapped in the heater box, another story! , still no power to brake light switch , the fuse that was blowing was number 1 it doesnt blow but still no brake or reversing light, are there any other fuses which could stop the feed, i have disconnected the brake switch and joined the wires to bypass the switch but still nothing ?
2015 +4 and 2000 4\4
1981 Lambretta GP225
1960 Lambretta LI 125
You need to double check the fuse - make sure you've changed number 20, and if you have a master fuse box on the bulkhead - check that also. Under dash - Fuse 1,2, and 3 are all named as "Engine" and 15A.
20 is diagonally opposite and also 15A, but bear in mind that this may not be accurate.
It sounds to me as if the short and blowing fuse might not be related to the brake lights?
You may have to trace back from the switch until you locate a break in the feed.
hugo Offline OP
Dave
I have checked number 20 fuse which is ok and there is power to it .
Auto electrician booked for Friday , i will keep you informed
Thanks for all your help
hugo Offline OP
Update... broken feed to the brake switch, where the wire had been trapped the core was showing but seemed intact, the break was slightly further up the cable, reversing and brake light fuse is No1 on my car ?!...On the road at last !!!
Black Rat
Black Rat
Good news indeed joy
Keith
2013 narrow bodied + 4 Ruby.
+1 good to hear.
Drive on the Wild Side
Well done Hugo, joy electrics can be very annoying, especially for me banghead
Adrian
+1 glad to hear you are back on the road
2025 MG ZS EV aka Trigger
Good news at last!
