7 members (AlyMatt, piquet, +8Rich, BobtheTrain, TBM, GrumpyPa, PaulV),
247
49
Posts838,002
Posts: 3,439 Likes: 7
Goodwood Drifter Talk Morgan Addict
Posts: 3,439 Likes: 7 |
hi,
my glove box has no "door" everything slides out of it ("ramp" is outside instead of inside)
can I order a "door" for it, or is it "stock" and did they just "forgot" to mount it at the factory??????
Steven sold: M3W, Aeromax,V6, 4/4 4seater now: +fourLM62
Retrobate Has a lot to Say!
Posts: 1,103 |
Ours came with a door as part of the 'walnut veneer' option - did not notice a chance to buy the door on its own...
Posts: 367 Likes: 1
Posts: 367 Likes: 1 |
Its only the Walnut veneer option that has a door. Painted and standard black are just a hole  Waiting on my new +4 with a painted dash and a hole. Andy
Posts: 234 |
Newish roadster should have the lozenge shaped door/hole, I like the new magnetic catches for these, the older door such as my wood dash 99 4/4 is a pain to get open without the key.
It is a help to put/lock away low value items when car is open.
Might be worth a wood dash upgrade, they certainly look nice.
Chris444
Posts: 453 |
Hey, Tokkie1560, no door is the price to pay for the originality of your so nice black & hermes roadster!  On mine, with the clasic wood board, there is a door (with invisible magnet locking). To be honest, the glove box is usefull for, heu.. 1 pair of thin holed gloves and a little piece of fabric. Not more. If you put too much inside it, it will press on the wheepers mechanism. So no door can be considered as a Plus Feature and an accelerometer as well: after a toll stop it mesures the acceleration from 0kmh to 130kmh. (tested by Mrs H3, as the driver, with my cigarets pack and my zippo falling on my laps from the unlocked glove box...) H3
H3
Posts: 17 |
Hi, there exist a simple cheap issue to your problem. You go to Auto-5 and buy a antisliding mat which is sold on roller of one meter (for car trunk) and easily cut. You can cut the piece you want and put it in the glove box, as it's black it's invisible and really efficient (I've put some pieces in my "every day business car" and it works well, every item stay on place when braking hard or cornering speedly). Best regards.
(I've put some pieces in my "every day business car" and it works well, every item stay on place when braking hard or cornering speedly). Best regards. might try that  was also thinking about a some kind of hook and a little black (or Hermes) bag no kidding found a hermes bag for sale in which the ladies keep their handbags dustfree when stored in their dressings
Posts: 17 |
Another idea I've found in order to solve the lack of space for item in my +4 : I've bought 3 "vide-poches" in a Longchamps shop. 2 are located in front of the seats behind the galvanised cross member, the other one is located behind the gear lever. They are made of fine leather with press buttons and exist in many colors, easy to combine with the leather of the interior. And, they are cheap (30 euro each..). It's looking fine and seems to be genuine. Best regards.
Posts: 27,838 Likes: 764
Posts: 27,838 Likes: 764 |
Go Mog has a fix to cover the windscreen moving rod by a tube, http://www.gomog.com/other.html#A%20DESIGN
Posts: 534 |
the older door such as my wood dash 99 4/4 is a pain to get open without the key. Chris444 I mounted a piece of wood in the glove box with a spring which bears on the back of the latch. Push the release button & the spring pops the door open about 10mm. See http://www.shirevillageinns.co.uk/mog/latch.jpgIan
3.7 Roadster 4" Ruston Procter SD Tractor 1905 Merryweather steam fire engine
