4 members (Paul F, Grumpy2, Rog G, TBM), 292 guests, and 40 robots.
+8Rich 65
Adam12 62
John V6 59
9,215 Registered Users
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Pur Sang Type 35
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,364
Posts813,343
Members9,215
#262318 25/03/15 08:02 PM
Farrmog Offline OP
Hi. Does anyone know where I can get my pair of Girling brake calipers reconditioned? Or if anyone does an exchange service?
Cheers
4/4 1982 crossflow Ivy
www.dentistandrewfarr.com
Farrmog #262334 25/03/15 08:49 PM
E
E
http://www.biggred.co.uk/
About £60 a piece plus say another £10 to get them their.
Sometimes just as cheap to buy recons
Farrmog Offline OP
Great I've just emailed them. Thanks
Farrmog #262338 25/03/15 08:59 PM
Another option- http://www.pastparts.co.uk/
Gerry.
Gerry
Farrmog #262394 26/03/15 01:35 AM
Brake engineering, Wrexham, google them!
1969 4/4
1995 plus 8
2002 Aero S1
2013 M3W
2014 Plus 8
Farrmog #262411 26/03/15 08:11 AM
What needs doing? If it's just the seals it's not a difficult job.
http://www.team.net/www/morgan/tech/mbrakes/art010_2.html
1972 4/4 2 Seater
Farrmog #262423 26/03/15 09:04 AM
E
E
I have rebuilt 5 caliper in the last few years are replaced two other sticky calipers with recons.
The recons have lasted the time.
Two of the re seals are still working the other three seal jobs have failed.
You just cannot make an older caliper with a less than perfect bore into a silk purse.
tmg513 #262594 26/03/15 09:27 PM
Farrmog Offline OP
The Pistons have ceased, new seals needed and they could do with a bit of TLC
Farrmog #262726 27/03/15 02:27 PM
Could be worth replacing the pistons with stainless ones as well as the seals.
Corrosion is a major cause of sticking pistons so check the bores.
As long as any corrosion that may be there has not affected the bores of the cylinders you will be ok.
Also, use a good spanner of correct size for the pipe fittings/bleed nipples.
Whilst at it also replace all the fluid...it should be done every 2 years or so.
Not expensive and a lifesaver!
sospan #262730 27/03/15 02:43 PM
Chances are there is somebody nearer Hereford offering to recondition calipers with stainless steel pistons. I use this firm for brake shoe re-lining, but they're not that far from me or my brother (think he picked up my last order).
Brake caliper reconditioning
