3 members (Image, Jon G4LJW, RichardV6), 238 guests, and 31 robots.
+8Rich 95
John V6 52
Posts838,002
rockabilly john
#26198 09/02/09 04:55 PM
1560 Offline OP
Goodwood Drifter
Goodwood Drifter
hi,
my glove box has no "door"
everything slides out of it ("ramp" is outside instead of inside)
can I order a "door" for it,
or is it "stock" and did they just "forgot" to mount it at the factory??????
Steven
now: +fourLM62
1560 #26200 09/02/09 06:37 PM
Retrobate
Retrobate
Ours came with a door as part of the 'walnut veneer' option - did not notice a chance to buy the door on its own...
1560 #26201 09/02/09 06:48 PM
Its only the Walnut veneer option that has a door. Painted and standard black are just a hole gloomy
Waiting on my new +4 with a painted dash and a hole.
Andy
Newish roadster should have the lozenge shaped door/hole, I like the new magnetic catches for these, the older door such as my wood dash 99 4/4 is a pain to get open without the key.
It is a help to put/lock away low value items when car is open.
Might be worth a wood dash upgrade, they certainly look nice.
Chris444
Hey, Tokkie1560, no door is the price to pay for the originality of your so nice black & hermes roadster! smile
On mine, with the clasic wood board, there is a door (with invisible magnet locking).
To be honest, the glove box is usefull for, heu.. 1 pair of thin holed gloves and a little piece of fabric. Not more.
If you put too much inside it, it will press on the wheepers mechanism.
So no door can be considered as a Plus Feature and an accelerometer as well: after a toll stop it mesures the acceleration from 0kmh to 130kmh.
(tested by Mrs H3, as the driver, with my cigarets pack and my zippo falling on my laps from the unlocked glove box...)
H3
H3
Q
Q
Hi,
there exist a simple cheap issue to your problem.
You go to Auto-5 and buy a antisliding mat which is
sold on roller of one meter (for car trunk) and easily
cut.
You can cut the piece you want and put it in the
glove box, as it's black it's invisible and really
efficient (I've put some pieces in my "every day
business car" and it works well, every item stay on
place when braking hard or cornering speedly).
Best regards.
1560 Offline OP
Goodwood Drifter
Goodwood Drifter
Best regards.
might try that cheers
was also thinking about a some kind of hook
and a little black (or Hermes) bag
no kidding
found a hermes bag for sale shocked2
in which the ladies keep their handbags dustfree
when stored in their dressings
Steven
now: +fourLM62
1560 #26224 10/02/09 03:47 PM
Q
Q
Another idea I've found in order to solve
the lack of space for item in my +4 :
I've bought 3 "vide-poches" in a Longchamps
shop.
2 are located in front of the seats behind the
galvanised cross member, the other one is located
behind the gear lever.
They are made of fine leather with press buttons
and exist in many colors, easy to combine with the
leather of the interior.
And, they are cheap (30 euro each..).
It's looking fine and seems to be genuine.
Best regards.
Go Mog has a fix to cover the windscreen moving rod by a tube,
http://www.gomog.com/other.html#A%20DESIGN
Chris444
I mounted a piece of wood in the glove box with a spring which bears on the back of the latch. Push the release button & the spring pops the door open about 10mm. See http://www.shirevillageinns.co.uk/mog/latch.jpg
Ian
3.7 Roadster
4" Ruston Procter SD Tractor
1905 Merryweather steam fire engine
