10 members (IcePack, Rex_tulips, +8Rich, Mauli, brownbaker, Grumpy2, Image, Tresco, RichardV6, TBM), 281 guests, and 34 robots.
+8Rich 64
Adam12 62
John V6 58
9,215 Registered Users
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Pur Sang Type 35
Tom Lehrer RIP
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,362
Posts813,328
Members9,215
Page 5 of 5 1 2 3 4 5
Originally Posted By Bassboy
Have fitted the K&N filters to both the carb and engine breather. On mine the larger main jet doesnt appear to be needed as there is no hesitation in in accleration or whilst on constant throttle settings however I will keep an eye out in case it develops. No nasty smells from the crakcase breather but the engine doesnt breath heavily anyway. A small but noticeable increase in performance which is a nice bonus. Over 150 miles so far with new setup. New shiny rocker cover fitted so underbonnet smarten up begun.(thank you ebay). EBC green stuff disc pad have made a marked improvement on pedal feel and braking. Thanks for all the advice, to someone new to Morgans, great chat room.
I haven't used the larger jet either, and there doesn't seem to be any hesitation etc. I rather like the new improved soundtrack.
Did you do anything with the exhaust manifold heat shielding? - I noticed that the HT leads sit directly above the hole where the hot air feed used to be and seems to direct hot air onto the leads, I wondered if it might be worth blanking this off somehow or ducting the heat away from the leads
Any thoughts?
With regard to the heat shield/collector on the exhaust manifold I removed this as I could see that it served no useful purpose anymore. This gave more air space around the manifold and removed the hotbits from near the wires etc. I have left the inlet in the front nearside inner wing clear as this will allow a flow of air over the exhaust manifold area. From previous experience getting air in is not as big a problem as getting the hot air out. So far, after 500 or so miles all seems ok.
Hi Keith
I am pleased to know your mod is still running well as I have just followed your approach. I used a 15,15 T and continued the copper pipe theme over & down into the crank breather filter. Hoping to try it out over this weekend
1984 Morgan 4-4
1959 Triumph TR3B
!977 Triumph Dolomite Sprint
