1 members (Alan Patterson), 210 guests, and 31 robots.
+8Rich 94
John V6 50
Posts837,998
rockabilly john
#266568 11/04/15 08:33 PM
I
inde101 Offline OP
I
Good evening all,
Can anyone tell me the size of the wire mesh fitted to the trades radiator grills please. I am about to order some from http://www.lockwoodinternational.co.uk but forgot to measure the grill. I know this isn't normally a problem but the Mog is back in Germany and I am in Southampton. pantsdown
Many thanks and has anyone used this firm before?
Cheers
Gaz
Gaz
I would order the mesh grille from a Morgan dealer or Heart of England Motors
Hi Inde, just measured mine for you, average 7.5 mm between wires - they vary from 7-8 !!
Height is 355mm, width is 322-329 mm, again varies.
Hope this helps!
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
I agree with Stewart. You will need to put a convex shape into the mesh to fit behind the grill and this will cause problems with the cut edges more than likely coming apart. The made up mesh grilles are welded and have a perimeter wire around them to hold the shape and cut down the chance of paintwork damage from raw edges.
Mine, from HoE, don't have a perimeter wire but, if I recall, the do have mounting plate at the top which matches the mounting points on the inside of the grill.
Mine's as Peter's, no perimeter wire but mounting plates at top. Not easy to make with the double curvature so not that expensive at £100 or so IMHO.
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
Mine as Peter's too.
Nick
I should have said that mine was from Simmonds!
CBY Offline
+1, good quality and nice look.
Regards
2005 PLUS 4
Hi Gaz
If you can weld buy the wire mesh.
Check out Mesh company the size of the mesh will change as it is formed to the Morgan grill, you will probably find it is a nominal 6.5mm.
If you are not a welder the mesh will unweave on the edges as you cut the corners , You will also have to allow for diagonal sizing not 90* mesh size.
Also where gloves the cut edges are very sharp.
Kind regards
Cain
Cain
Wolf Cafe Racer
4/4 Sport
