5 members (+8Rich, gomog, sewin, Ricosan, CJB), 233 guests, and 131 robots.
+8Rich 75
Topics49,868
Posts837,651
Moggo
Stephen Offline OP
I returned home in the car today, opened the garage and saw a couple of drops of oil on the floor. On inspecting the car I can see a large amount of fluid, largely on the underside near the passenger front wheel (it's all over the interior of the wheel too).
I've checked the oil and it's certainly not from the engine. Does this sound like a suspension issue? It is definitely oil.
Current: Aero SuperSports
Previous: Aero 8 S3
Want: Aero 8 GTN
Power steering fluid is on that side? also the auto gearbox cooling pipes?
Martin (Deano)
Are you certain it isn't brake fluid?
Mark - No Longer driving
Stephen Offline OP
Thank you for the quick response guys.
I've had a poke around and found what I suspect to be the culprit (a loose jubilee clip by the looks of it - there is no fluid above this area). Am I right in thinking this is the power steering?
Previous: Aero 8 S3
Want: Aero 8 GTN
It's hard to see from your photos but if it's the connections above the front suspension, its the auto gearbox.
Martin (Deano)
Stephen Offline OP
It's not visible in these pics but it connects with that radiator type thing at the top of the first picture. I wondered if it was just coolant but it feels oily to touch.
Previous: Aero 8 S3
Want: Aero 8 GTN
I think that's the oil cooler for the gearbox...........
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
Stephen Offline OP
Many thanks all - I'll have that looked at first thing tomorrow.
All I say is thank goodness for concrete garage floors or I would have missed this... eek
Previous: Aero 8 S3
Want: Aero 8 GTN
If its the gearbox cooling system, don't forget to check the gearbox oil level.
Martin (Deano)
Formerly known as Aldermog
Under the nearside wing is an oil/water heat exchanger for the auto box fluid.
In my view not the most sensible place to put it as it is exposed to road crud and stuff.
