Morgan Aero 8
2 members (+8Rich, MartO), 114 guests, and 29 robots.
John V6 63
My Goodwood Revival 2026
Clutch for a 1982 4/4
DVLA frustration.
Old Book
by Pundit - 21/09/26 01:39 PM
First Morgan as it is now
by Strathaven, September 15
Topics49,940
Posts838,603
greenteagod
Ale_72 Offline OP
Does anybody has a list of batteries that can replace the factory Banner Uni Bull?
Or at least dimensions of the battery and tech specs (I am too many km far from the car to check it)
It would probably be enough to know the model ID
http://www.bannerbatterien.com/banner/produkte/batterien/uni_bull/
Thanks
When mine died it was replaced by BMW with a BMW branded battery - with slightly different ratings.
I have had no problems with it. I can send you a picture tonight.
2010 Aero Supersport | 2017 VW Multivan | 1996 BMW M3 Evo
Ale_72 Offline OP
Thanks!
If the BMW part number is visible, that would help as well.
Ale_72 Offline OP
Thanks to dodgyken, it will be easy to find a replacement.
Dimensions are: 242 x 175 x 190
So I guess that is the Banner Uni Bull 50 300
It's a quite common battery, used in a lot of BMWs.
http://realoem.com/bmw/partxref.do?part=+61218377139&showus=on&showeur=on
So it should be quite straightforward to find the Varta, Bosch verions (just to name two common, well known, brands).
Replaced mine 2 years ago and still working, with a BOSCH 075 SILVER S4. 12v 60Ah. 242Long, 175Wide, 175High
You'll also note that BMW reverse fitted the new battery - IE the terminals are now swapped over back to front in the engine bay. IIRC it is a neater solution to Morgan's install
Ale_72 Offline OP
Used the same Bosch silver from Halfords. Works very well.
Ale_72 Offline OP
Dodgyken could you make me another favor? Could you please check height of your BMW battery? Is it 175mm or 190mm?
From base to top it is about 190mm - to the lip it is 180mm
