2 members (nick w, JoeSpeetjens), 348 guests, and 88 robots.
Topics49,847
Posts837,389
MGDave Offline OP
I'm preparing for a trip to South Carolina about 850 miles each way. I've changed the engine oil, greased all the zerks and now its the turn of the transmission. Not sure what oil to use, all the oils listed in the manual aren't available in Canada. Help would be greatly appreciated.
Dave
Dave
98 +8 Corsa Red
74 MGB Red
Dave
If you have the LT77, have you read this?
http://v8registerdata.net/viewreply.asp?id=3676&mtid=%281,2,3,4,7,8,9,10%29
If you have the R380 box it's MTF94 although I used Comma AQF M2C-33F/G to the same spec as per the You Tube which will identify the box for you if you are not sure.
It also provides several different manufacturers oils.
Mine didn't have an inspection hole in the tunnel so I did it from underneath with a syringe and it worked ok 2.9Ltrs needed.
https://www.youtube.com/watch?v=8PhpKFNZLy8
And another covering both boxes oil types.
https://www.youtube.com/watch?v=WEXd4J3tq-k
That sounds like one nice road trip - pictures always appreciated here.
MGDave Offline OP
Thanks for the advice, I have the R380 box, will checkout YouTube.
Thanks Again.
Dave
98 +8 Corsa Red
74 MGB Red
Yep used the MTF 94 in my R380 box but just over 2 litres as I was told... Couldn't put more in as it was coming out the top up hole..it's tricky to get the filler plug out as its close to the chasis so resulted in a square 55 bit and a spanner..
MGDave Offline OP
Having a problem finding an equivalent to MTF94 in North America. Does anyone have any suggestions?
Dave
98 +8 Corsa Red
74 MGB Red
Drive on the Wild Side
gearoil try this they ship internationally, there is a a Fuchs equivalent but whatever you buy make sure it meets the API GL-4 SPEC
Adrian
Do you have a Land Rover dealer nearby?
They should be able to provide an equivalent to MTF94.
The link below lists a few suppliers on ebay if this works for you Dave.
http://www.ebay.co.uk/sch/i.html?_nkw=mt...stpos&gbr=1
MGDave Offline OP
Thanks to all for your help, I made a purchase on line today.
cheers
Dave
98 +8 Corsa Red
74 MGB Red
