0 members (), 290 guests, and 90 robots.
+8Rich 77
Topics49,870
Posts837,668
Rudolf
I saw an Aeromax in a at Mogworks with just that problem.
The connections I understood are special & from BMW
On my S3 I have had fluid in much the same place, but although it takes an age to evaporate so makes you think it's oil at first, it's been either water from the wash bottle reservoir or coolant from the joints with the radiator. I think there's a weak connection between the reservoir and the headlamp washers.
I get the fluid on the nearside just in front of the front wheel and on the steering rack dripping down. It's been fixed a few times but does tend to recur on the (my) S3 although the leak is always slow.
Pardon mentioning it as an S3 manual is a good bit different but I was a bit worried and it turned out to be a much more minor problem than I'd thought! Hoping yours is too!!
Stephen Offline OP
Yesterday I had the jubilee clip on the automatic gearbox hose tightened and levels checked. To be on the safe side I've booked the car in for a full service the week after next.
I believe this started a week or so ago when a suicidal pheasant went under the front wheel and then seemingly disappeared. My guess is the carcass went up, bounced around (knocking the hose) and fell out sometime later. Yuck...
Thanks again for the comments. smile
Current: Aero SuperSports
Previous: Aero 8 S3
Want: Aero 8 GTN
If it had stayed underneath for any length of time it would have dropped out cooked its gets hot under there.There are also quite a few vunerable wires but most probably now sorted on the super sports.
Em
Stephen Offline OP
Em
Caught, killed and cooked, if only I could fit a device to pluck it too!
Previous: Aero 8 S3
Want: Aero 8 GTN
Stephen Offline OP
Update - I had the hose tightened and gearbox oil topped up but it started leaking again on our last drive, which was fortunately to the Morgan factory!
Apparently this is a common problem - the metal the hose sits over corrodes (inside the hose) and the part (not confident which part) needs replacement at around £500. Sounds like a weakness Morgan or we should address as nothing like this should fail in such a short time.
Previous: Aero 8 S3
Want: Aero 8 GTN
Formerly known as Aldermog
The unit on my Plus 8 was weeping fluid: MMC replaced it under warranty.
There is a similar unit on my BMW, loks as if it is the same BMW part, but it is inside the engine compartment, not exposed under the wheel arch. Really not the brightest place to put it.
Stephen Offline OP
Agreed Peter, not ideal and it seems this will go for everyone at some stage.
The part isn't in the parts diagram but can be seen here:
http://www.pistonheads.com/pics/news/19800/tn_MogChassisTest-L.JPG
For others, look at the box in the front wheel well with two hoses coming out beneath (and some gubbins above).
Does anyone know what the BMW part number is? I'm going to see if there's a stronger aftermarket part or some way of protecting the unit - I really don't want to be replacing this every five years!
Previous: Aero 8 S3
Want: Aero 8 GTN
Stephen Offline OP
Update again - it looks like part 17217505823 (BMW) but can anyone confirm?
Previous: Aero 8 S3
Want: Aero 8 GTN
