Topics49,859
Posts837,507
Posts: 1,873 Likes: 174
Posts: 1,873 Likes: 174 |
Yes, I like these black wires to, but what a large "balloons" tyres! Magnificent car.
Compliments from another Ruut with a "t" at the end!
Ruut Bianchi Morgan PlusFour 2023 Bentley Midnight Emerald Morgan 4/4 4-seater 1990 Royal Ivory
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
Some super cars
Has anyone found out or know what the spec of the paint finish on the painted wheels are yet ?
Posts: 14,009 |
Some super cars
Has anyone found out or know what the spec of the paint finish on the painted wheels are yet ? According to the MWS website .... The MWS wire wheels are primer coated using Cathodic Electrophoretic technology. This increases the corrosion resistance to very high levels. A topcoat of silver ash or black follows this. The paint system provides salt spray resistance of 840 Hrs when tested and evaluated on panels as per ASTM B117. Not sure if that means they are powder coated or not...!
Some super cars
Has anyone found out or know what the spec of the paint finish on the painted wheels are yet ? Not sure if that means they are powder coated or not...! Thanks for the info I know what you mean - I've just read up on It, and I'm non the wiser I guess it means - it's a pretty thorough tough coat
Posts: 12,257 Likes: 317
Posts: 12,257 Likes: 317 |
As far as I'm aware, electrophoretic coating is when the item is charged and dipped into a tank of liquid which makes the coat. So not, it's not like powder coating at all, except in the sense that the coating sticks to the surface being coated via an electric charge.
Posts: 676 |
As far as I'm aware, electrophoretic coating is when the item is charged and dipped into a tank of liquid which makes the coat. So not, it's not like powder coating at all, except in the sense that the coating sticks to the surface being coated via an electric charge. But that is just the primer coat as mentioned by Jay. The top coat I would imagine is EPC (Electrostatic Powder Coating). The salt spray test however does not give a good indication of longevity of the coating in real environments however its an Automotive standard test which is used almost universally even for steel parts inside the car such as the metal in seat belts with a plated surface.
1989 911 Porsche Carrera Land Rover Series Defender 90 SW
Posts: 1,947 |
MWS have introduced Turrino alloy wire wheels.
Just been on the MWS website for the first time
It's pretty good and it's quite pleasing to see that the painted and chromed wires for a Morgan are not ridiculously expensive if I ever needed to get hold of some
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
It's pretty good and it's quite pleasing to see that the painted and chromed wires for a Morgan are not ridiculously expensive if I ever needed to get hold of some Indeed and when I swtiched from painted to chrome they were even cheaper to buy them directly from MWS in Aus than the UK
Richard 1976 4/4 4 Seater
Posts: 1,502 |
I have MWS s/s wires which I bought in 2007 to replace to replace the original chrome wires (2004 built 4/4) as I didn't want to spend hours cleaning and polishing. 7 years on the s/s wires are like new and only ever get washed. Worth every penny IMO. Nigel.
