10 members (Graham, G4FUJ, cerealsurfer, DCH, High Hamster, Montegue, JamesS, MartO, Joske Vermeule, TeddyAds, sewin),
303
64
Topics49,860
Posts837,522
Posts: 120 |
My Brooklands distances are, 3.5cm N/S and 3.0cm O/S
It's after that that all goes to cock with my offside can coming into contact with the heat shield despite obvious "fettling" pre delivery.
Posts: 242 |
Stan - do you have the welded headers?
Posts: 120 |
Good point, meant to mention that, yes, both are welded.
Posts: 3,732 Likes: 79
Posts: 3,732 Likes: 79 |
Red Leader
Posts: 1,642 |
Thank you Chris!
Although the camera angle might alter our perception, I guess that the picture of the right side header, even without the vertical line on display, hints that this header is also shorter than almost all others pictured in this thread, exceptions being my own car and maybe Robert's (Grockle's).
One interesting thing is that when my mechanic mentioned that the problem was the "shorter" section of the header (between engine head and where it turns to the back) I told him that maybe the problem wasn't in the length of that particular section, but that the shape of it was bent downwards.
He said "no, it's not that. I measured the distance from the bottom of the header to the floor and it is exactly the same in both sides. The problem is that the header is shorter and therefore turns to the back of the car before clearing the bottom of the spring."
I really need to get hold of all measures. And I will probably ask for a new header (or the pair of them?) from the factory, under warranty.
I tell "yous", the two years we're given to iron out all these things aren't too much. Considering after all is properly set up, that's when the warranty period should start.
But as kids nowadays would say ... Keep Calm and Ride On
Posts: 1,947 |
How do they get that polished bronze look on DE above? Mine look more like PE. I've tried several cleaners/polishes & they last no time at all.
Tim
How do they get that polished bronze look on DE above? Mine look more like PE. I've tried several cleaners/polishes & they last no time at all. I think it might just be that DE is lower mileage. Mine started off like DE but are not definitely PE
Red Leader
Posts: 1,642 |
Agreed, after a few "glowing" miles they lose their shiny look. Just have a look at mine when compared with MO63WLR's. Last two pictures from this post
Posts: 1,642 |
Sorry to revive this old thread, but I have news regarding the front clearance issue between exhaust header and Suplex suspension. I'll quote the relevant part of my own post from a few pages back UPDATE ON XF14 AEF The clearance issue raised its ugly head again. It won't happen often, but a more pronounced bump will make the right exhaust header hit the bottom of the spring. This, evidently, cannot be, and I'm still puzzled by how can it- all of it - be possible. But the mechanic told me it might indeed be that this is an issue with my car and my car alone, due to what he suspects is a faulty right exhaust header. One that he says is SHORTER than it should. And he demonstrated this to me with two pictures he took with his smartphone. As you can see in them, the left header ends up farther away from the center of the vehicle than the right header. The turn signals were used as reference points to draw a vertical line from them ( I lack the English words to explain what's in the picture, but you guys can see it clearly I assume) Here the pictures: RIGHT SIDE LEFT SIDE Before I jump to any conclusion (and if the conclusion is that my right exhaust header is defective then I will ask for a new one ...), I'd like to call on my fellow TMers that are also M3W owners and ask them to take, and post here (or send me by email to mcp@cps.com.pt , if you prefer) the same pictures, but of their own cars. Left side and Right side, with a vertical line from each turn signal. Hope you guys can help me out with this ... I'm really next to quitting the Suplex suspension altogether. And it's a shame because it transforms the car's handling (front) for the better. Thanks! Now, almost one year past, I'd like to say again a big "THANK YOU" to all of you that gave yourselves the trouble to take pictures of your own cars front suspension so I could "make my case". Because I made it, and MMC rose up to the occasion. I'll name you, oh pictografic benefactors !!! - MO63WLR - The Austrian - NADVYS - Grockle - Chris99To make a long story short, with the help of your pictures and a couple more measurements made, MMC agreed that my right hand side exhaust header was incorrectly shaped and they sent me a new one. Because the new one is ... uhh ... new, and the visual difference between the new and the old (Left Side) is nothing less than shocking, I asked to have them wrapped when installed. That was made today. Here the result. As you can see the new header has a nice good clearance regarding the suspsension. I don't like the visuals with the wrapping (couldn't find black or dark material), but I'm told they'll soon get darkened by use and heat. Here the result:  One more properly ticked box, a few to go ... to be continued!
Posts: 1,796 Likes: 5
Posts: 1,796 Likes: 5 |
Great result, I'm glad it is now sorted at last.
