0 members (),
192
72
Topics49,861
Posts837,542
Posts: 22,362 Likes: 353
Posts: 22,362 Likes: 353 |
75th Anniversary models are in short supply...canny owners like DaveW hanging on to them...so it may have to be a GDI. But if something worth having turns up 'sometime', I may have to let Bumble go. It would have to be at least another 45bhp though. The only time I've grounded so far with the Roadster was in the British Legion Car Park at Bourton on the Water where there is a deceptively high full width extended hump, and when I came off it at car park speed, I took a knock and scrape, which luckily didn't do any damage. You can get stuck on the gearbox crossmember because its an inverted U - Keith at BHM suggests a steel cover plate over the lowest point - this will reduce clearance by the thickness of the metal but present a flat profile instead of the inverted U. Not necessary on 3.0 Roadsters because as has been said, the sump and bellhousing are both lower than the crossmember.
Posts: 14,748 Likes: 158
Posts: 14,748 Likes: 158 |
Dave, I managed to get the cross member stuck in a gap on the ramp of a Lake Como ferry. That was interesting to say the least. Basically the problem with Plus 4 ride height, and to a lesser degree Roadster (without considering the sump problem), is the tyre choices made by Morgan. To quote an ealier post of mine: For anyone interested I have used http://www.1010tires.com/tiresizecalculator.asp to create a chart of comparison between the standard tyre sizes quoted by Morgan in the user manual plus the 195/65 variation. You can look at it if you are interested. http://bradley.it/public_images/Tyre%20sizing.pdfTo sum it all up variations in axle centre height based on the tyres alone are: 4/4 12.69in or 322.32mm, Plus 4 12.10in or 307.34mm, Roadster 12.34in or 313.43mm, 195/65R15 12.49in or 317.24mm In theory this means that the Plus 4 has the lowest ride height followed by the Roadster and that the 4/4 has about 15mm or more than half an inch more ground clearance than the Plus 4. If you are worried about ground clearance, the best choices for a Plus 4 would be the narrow bodied version with 4/4 wheels and tyres followed by 195/65 R15 tyres if the standard width body. The Roadster would be better fitted with 205/65 R15 tyres which would also allow a 4/4 wheel and tyre to be used as a "space saver" spare.
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
Last year I grounded the Plus8. We were on Cefn Bryn on Gower near Arthur's Stone and King Arthur Hotel. The cross member was on a large stone. I had to get under to remove it, luckily it was loose enough. As for speed bumps..... I wonder if there is a spec for their size/profile. They are either preformed and bolted down or just a mound of ashphalt of varying shape and size. There are far too many now. A mate has noticed having to change more springs on cars over recent years as their numbers increased.
Posts: 881 |
Sleeping policemen are the devils work Very true
Very much in the dog house, could be up for rehoming
Posts: 27,813 Likes: 749
Posts: 27,813 Likes: 749 |
Being the owner of a 3.0 Roadster I approach all speed bumps with trepidation! Even though I have a Mulfab sump fitted, the engine still sits low, and if the sump doesn't hit, the bottom of the bell housing does, often followed by the gearbox crossmember.
I'm interested in the comparison between the Duratec and the GDI ground clearance as I'm considering a narrow bodied version. The 75th Anniversary models are in short supply...canny owners like DaveW hanging on to them...so it may have to be a GDI. +1. They are a clear & present danger. I am the Chairman of the committee that runs our private road. We have 7 of them in 1/2 mile. One new comer to the road asked to add two more!!!
Posts: 163 |
+1. They are a clear & present danger. I am the Chairman of the committee that runs our private road. We have 7 of them in 1/2 mile. One new comer to the road asked to add two more!!!  ... the new comer is doing the devils work on earth  ......
Torsten
plus 4 MY 2014
Posts: 6,958 Likes: 117
Posts: 6,958 Likes: 117 |
Devil's Advocate. Brilliant film.
Posts: 213 |
Just been out to measure clearance on the +4 - best I can get is approx. 95 mm to the cross-member, approx. 100 mm to the bottom of the thread of the gearbox mounting bolts, approx. 105 mm to the bottom of bell housing and approx. 111 mm to the bottom of the forward exhaust mounting bolts. From the snappily titled 'The Highways (Road Humps) Regulations 1999' it seems to me that road humps should be no less than 25mm or more than 100 mm high. This makes the ground clearance of my +4 very tight indeed even on correctly installed humps. I'm sure some humps are more than 100 mm though ....
Richard +4 GDI Connaught Green, 2014 Magnolia
Posts: 7,553 Likes: 88
Posts: 7,553 Likes: 88 |
Richard Unless you are extremely slim or have very long arms, how on earth did you manage to measure those?
Bud 4/4 "Stanley"
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
The Poadster, before fitting the MulFab sump, was 83mm...
The Plus 8 is exactly 100mm on its 19" wheels with 35% profile tyres and the sump is steel, not cast alloy. It is, after 18500 miles, unmarked. (Unless the factory replaced it before sale....)
