8 members (Graham, G4FUJ, Chris Cosher, Morganmike, ScotiaSteve, TBM, SteveT, Simon, teknome),
313
95
Topics49,859
Posts837,481
Posts: 1,103 Likes: 17
Posts: 1,103 Likes: 17 |
Hi, I am a problem, my fuel gauge, thinks there the tank is just under half full no matter how much fuel is in the tank, any idea how to fix this.. Will
Posts: 15 |
Possibly the float/sender unit in the fuel tank sticking. I had this with my Mercedes G-Wagon. The other possibility, which is much more straightforward, is that the gauge itself is sticking if it doesn't ever change which is a simple matter of replacing it or having it repaired by a gauge specialist.
Andy
could be fuel sender.. might take it out.. to free it up.. Will
Posts: 534 |
Does the gauge go to empty with the ignition off? If so, it's not likely to be sticking, so more likely to be the sender Ian
3.7 Roadster 4" Ruston Procter SD Tractor 1905 Merryweather steam fire engine
