4 members (Montegue, Vansrv6, TBM, BHV), 278 guests, and 33 robots.
+8Rich 92
Posts837,277
Page 3 of 3 1 2 3
Ah....the charms of Morgan!
My bolt heads rotated slightly as the runners didn't hold them tight so stilson used to control them and prevent damage. The new socketheads removed this problem
You were lucky!
Had the same problem with my 2014 +4. I did drill into the floorboard to countersink the bolts fixing the seat runners but that didn't really solve the problem. Part of the reason that the bar under the runners bends - at least on mine - is that there's about 3-4mm difference centre to centre in the bolt holes between those in the chassis and those in the bar under the runners. Out with the file and extended the holes in the bars to match the chassis centre to centres, reattached to the runners, and that seems to fix the issue.
Page 3 of 3 1 2 3
