8 members (IcePack, Rex_tulips, +8Rich, B&C Morgan, BobtheTrain, nick w, howard, RichardV6), 339 guests, and 26 robots.
+8Rich 64
Adam12 62
John V6 58
9,215 Registered Users
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Pur Sang Type 35
Tom Lehrer RIP
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,362
Posts813,329
Members9,215
Mine also has the grease nipple fitted, twice a year I give it about 10 pumps of JCB high pressure waterproof blue grease. It runs as quiet as a whisper at all speeds and loads even down to 2000rpm
The hole in the bell housing is about 1-11/4" dia. This is not critical.
To get a datum measure the centre of the compensator at the top through the steering rack cut out and transfer the measurement to the bottom.
Hope that helps.
Couple of photos showing a compensator complete with grease nipple packed with grease while being assembled on the bench and a compensator housing showing the cutaway on the top for the steering rack and the hole that was drilled for access to the grease nipple.
Hope this helps.
Grease packed compensator c/w nipple
Drilled compensator housing
Thanks guys for the information and pictures. Sounds like a must do.
LarryS Offline OP
Thanks, already had the compensator replaced. I'm pretty sure it's a chassis type noise. I squeezed some heavy grease into a few likely locations. I'll see if that made any difference. LarryS
Hi
Check for cracks around the exhaust mountings
