3 members (Sir Percival, MartO, Mark+4), 156 guests, and 34 robots.
John V6 63
My Goodwood Revival 2026
Clutch for a 1982 4/4
DVLA frustration.
Old Book
by Pundit - 21/09/26 01:39 PM
First Morgan as it is now
by Strathaven, September 15
Topics49,940
Posts838,609
Page 3 of 5 1 2 3 4 5
Tow backwards
On an A frame? How would that help?
Formerly known as Aldermog
Originally Posted By Hamwich
Tow backwards
Front wheels on the road, rears on the frame?
All four on the floor with an A-frame Peter... smile
Tow backwards
That's what I was thinking....
Ray Offline
Tow backwards
If you tow like this, first check that your steering locks straight ahead, or you will have a very interesting drive. scared
Tow backwards
Then it would be called a "Suspended tow".
I used to have a suspended tow trailer when doing rally recovery. A flat tow, using an A-frame, all the towed vehicle's wheels are on the deck - used one once to bring a friend's daughter's expired car back from Bridgewater to Cheltenham. Got soaked as had to re-rig the thing in the pouring rain after a couple of miles.
Terminology chaps... smile
I thought the issue was that if you tow certain Mogs the gear box is trashed as the oil pump is driven by the input, not output side of the box. So towing on the rear wheels causes the box to turn without proper lubrication = trashed gear box.
A suspended tow with front wheels on the ground means no gear box damage. Perhaps.
Ray Offline
I think we are all mixing up, A frames with tow boys, where there is a lift of 2 wheels off the floor.
Exactly, hence my comment. An A frame, as Graham pointed out, keeps all the wheels of the towed vehicle on the ground.
I was just pointing out an error in an earlier comment re: towing method...
(13.5 years approx. running a rally recovery unit, with a Tow Boy - see photo of 127" LR I have posted more than once... A year doing commercial recovery with various suspended tow vehicles in between other work...)
Your first paragraph is correct BTW...
