3 members (Strathaven, Luddite, Alistair), 129 guests, and 26 robots.
John V6 63
Silicon cf. Silicone
by JMcL - 24/09/26 10:21 AM
My Goodwood Revival 2026
Clutch for a 1982 4/4
DVLA frustration.
Old Book
First Morgan as it is now
by Strathaven, September 15
Topics49,941
Posts838,623
Page 4 of 5 1 2 3 4 5
Gone to Porsche
Gone to Porsche
Originally Posted By PhilipNZ
Prop the clutch fully in with a stick and leave in gear :-)
10/10 .....sending your star in the post
The oil pump will be rotated, as all shafts will be rotated, top gear is recommended
By the time you have found an appropriate stick surely you could have disconnected the propshaft at the diff end.
1992 plus4 connaught green
Gone to Porsche
Gone to Porsche
Ye but then you have to hang the prop or remove, loosing all oil out of the tail housing sick
I don't understand. What is the tail housing?
Bit of the diff (sort of) that the prop fits/installs into.
So why does undoing the propshaft from the diff flange entail loosing any oil?
Unless Morgans are different to every other car I have owned is a sealed item with oil seals on at the input and outputs.
So why does undoing the propshaft from the diff flange entail loosing oil. Unless Morgans are different to every other car I have owned the diff is in a sealed housing with oil seals at input and output shafts.
Ray Offline
Tail shaft is the back of the gearbox. Prop acts as an oil seal. Or at least fits in an oil seal to prevent loss of oil.
Well I am amazed. I have had to take the prop shaft off my Discovery to replace the uj bearings, and the drive flange on the rear of the gearbox, same as Morgan, was held by a large central nut and had it's own oil seal. This nut is a swine to remove as I had to, later, replace this said oil seal.
ATL Offline OP
Thanks for the interesting replies, i will certainly investigate the gearbox issue.
