10 members (MJF, sospan, deano, Mogdavid, Plus Four Guy, rossocorsa, Ralf58, jbk, TBM, DickJ),
109
Old Book
Topics49,941
Posts838,620
Gone to Porsche Part of the Furniture
Posts: 4,333 |
Prop the clutch fully in with a stick and leave in gear :-) 10/10 .....sending your star in the post The oil pump will be rotated, as all shafts will be rotated, top gear is recommended
Posts: 1,616 Likes: 1
Posts: 1,616 Likes: 1 |
By the time you have found an appropriate stick surely you could have disconnected the propshaft at the diff end.
John 1992 plus4 connaught green
Posts: 4,333 |
By the time you have found an appropriate stick surely you could have disconnected the propshaft at the diff end. Ye but then you have to hang the prop or remove, loosing all oil out of the tail housing
I don't understand. What is the tail housing?
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
I don't understand. What is the tail housing? Bit of the diff (sort of) that the prop fits/installs into.
Richard 1976 4/4 4 Seater
So why does undoing the propshaft from the diff flange entail loosing any oil? Unless Morgans are different to every other car I have owned is a sealed item with oil seals on at the input and outputs.
So why does undoing the propshaft from the diff flange entail loosing oil. Unless Morgans are different to every other car I have owned the diff is in a sealed housing with oil seals at input and output shafts.
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
Tail shaft is the back of the gearbox. Prop acts as an oil seal. Or at least fits in an oil seal to prevent loss of oil.
Well I am amazed. I have had to take the prop shaft off my Discovery to replace the uj bearings, and the drive flange on the rear of the gearbox, same as Morgan, was held by a large central nut and had it's own oil seal. This nut is a swine to remove as I had to, later, replace this said oil seal.
Posts: 2 |
Thanks for the interesting replies, i will certainly investigate the gearbox issue.
