1 members (+8Rich), 385 guests, and 74 robots.
+8Rich 82
Topics49,849
Posts837,425
#279718 07/06/15 07:41 PM
Smaug Offline OP
Had a vibration since two days in the right Headlight, checked and found a crack in the base of the housing (common issue already threated in this Forum) mad
Those who had this issue...are there alternative (better quality) solutions as replacement for the Morgan Headlights? I just upgraded the Headlight inserts to quality Harley ones which makes me stay on the 7" size to keep the inserts.
Any ideas for 7" housings for my 3W sos
Cheers,
Georges
Q
Q
See those but they are too modern for the m3w
http://www.ebay.com/itm/New-7-Inches-LED...160&vxp=mtr
I'm using the J.W. Speaker LED's which are a modern lamp and they do not look out of place on this car. There are better quality lamp buckets out there. If you like it try it!
It's like taking an older wooden sail boat and refitting it with stainless fittings and nylon instead of hemp rope. Some will grumble and others will say "cool!"
Smaug Offline OP
Thanks for your replies...but I just want the housing....I bought the Inserts from HD in a better quality already drive
Cheers,
Georges
I am also looking as it sounds are many others. Phone call to Morgan again I think.
I am really struggling to find anything good quality
Andy
Smaug Offline OP
Hi Bunny, I think that will do the trick...thank you thumbs the housing from the 'Europa' site is what I am looking for.
Cheers,
Georges
Smaug you will have to cut the wire to pass it through the mounting bolt so ensure you have connectors. I believe RedThree had one reploaced under warranty. My RH lamp vibrates & wont stay in adjustment.
Tim
Smaug Offline OP
Talked to my dealer on Monday. He sayd that it is under garantee and had already ordered a spare Headlight body (in stock at Malvern happy3) should be here end of the week / begining next week....would be fair to me. If that happens again, then I will reconsider to buy new Headlights in a better Quality...
Thanks for all your replys thumbs
Cheers,
Georges
