Topics49,842
Posts837,332
Posts: 2,125 Likes: 37
Posts: 2,125 Likes: 37 |
I have a split in the nearside wiper blade on my 2008 Plus 4, which will need replacing before the MOT. Can the rubber just be replaced, or is it a case of replacing the assembly back as far as where it clips on the arm? If just rubber replacement is it generally available (in, say, Halfrauds?)
Regards Alan AP08 MOG 2016 Plus 4 GDi - Mazda Soul Red Metallic
Posts: 987 |
Complete Wiper arm is about a tenner, you can't replace the rubber for that. Bhm are very good for that sort of spare.
Posts: 987 |
Sorry I meant wiper blade back to the clip on the arm.
Posts: 14,748 Likes: 158
Posts: 14,748 Likes: 158 |
I can't believe we are still using wiper blades that were invented before the war - first world war that is.
Hasn't anyone found a better solution? We all know that it never rains in England but on the odd occasion that it does you would have thought someone would have had the initiative to design a system for the Morgan that actually makes vision through the windscreen possible.
Hasn't anyone found a better solution? We all know that it never rains in England but on the odd occasion that it does you would have thought someone would have had the initiative to design a system for the Morgan that actually makes vision through the windscreen possible. They have - aero screens!!
Posts: 3,383 Likes: 14
Posts: 3,383 Likes: 14 |
I have a split in the nearside wiper blade on my 2008 Plus 4, which will need replacing before the MOT. Can the rubber just be replaced, or is it a case of replacing the assembly back as far as where it clips on the arm? If just rubber replacement is it generally available (in, say, Halfrauds?) Someone posted a link to a Land Rover specialist (so I suspect it may have been Graham?) I bought 3 blades from them, posted to Leicester for under a tenner. They are a tad longer but cut easily with tin snips. Also they are black, thought it might look a bit off but on a silver car they look fine. Much better quality and clearing capability then the MMC ones as well as as I was cutting them trimmed to give more sweep area.
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Rainex is quite good....but not a full replacement. The Australians have a solution too - WA works 99% of the time
Richard 1976 4/4 4 Seater
Posts: 28,892 Likes: 350
Posts: 28,892 Likes: 350 |
I think it was Smithy (Lord U) on either MT or NBC Colin...
Posts: 4,896 |
Alan, I have some spare wiper blades in a draw in the garage, they were off my plus 8, not great but get you through an mot. If you'd like one I'll select the best and pop in the post. PM me if you want one.
Adrian
Posts: 3,480 Likes: 42
Posts: 3,480 Likes: 42 |
I have "manufactured" replacements by using parts of modern Bosch Wipers. I am very happy to say that they actually work and wipe the screen rather than spread the smear about like the standard ones. I will get around to photographing the bits and the process and will post here -- they make a huge difference!!
Cheers!
