9 members (+8Rich, RichardV6, BillHart, mph, sbarracl, Adam12, TBM, Ian Wegg, Alan Patterson),
462
40
New
Topics48,365
Posts813,385
Members9,215
Posts: 2,403 |
I have seen an early Aero where the drive shaft bolts are hanging out. Scary moment that was!!
Posts: 1,597 |
I have seen an early Aero where the drive shaft bolts are hanging out. Scary moment that was!! My driveline shunt seems to be more noticeable when I returned from MOG 15. How accessable is it to check the drive shaft bolts
Posts: 27 |
You will need to jack the car up at the back enough so you can slide yourself under the car, and then get a spanner to the bolts.
Morgan Plus 8 Speedster -------------------- 2015 Defender 90 - Twisted/Bowler Mix --------------------
Posts: 1,597 |
Hellfinger, Many thanks, I am hoping this is the problem.
Posts: 27 |
I have been told by the factory it's worth checking every 500/1000 miles depending how much stick you give the car I guess  it's supposed to be one of the main things to check every service but dealers don't seem to know about this ?
Posts: 536 |
I do check the drive shaft bolts at the annual service, but have never found any loose over the 7 years and 40,000km I've done with the car.
Cheers
Philip
1985 Plus 8 four seater Malone F1000 - track car
Posts: 2,384 Likes: 56
Posts: 2,384 Likes: 56 |
I think the factory make things up as they go along,its the first time ive heard of checking every 500 mls.Mine are loctited not that it means very much.
Em
Posts: 9,285 Likes: 69
Posts: 9,285 Likes: 69 |
If a bolt/nut needs tightening after 500 miles then there is a major issue with design. Such nuts should have a locking mechanism Nyloc/lock washer/threadlock/pin/lockwire. I find it alarming that the factory reccomends checks that often and not upgrade to make the design safer. Ok...I have a trad and periodically check nuts/ bolts in some areas such as rear axle u- bolts etc.but not found any slackening to date. The regular greasing that is advisable on the suspension etc is acceptable and allows a quick undercar check at the same time but driveshaft bolts/nuts at that frequency? A bit frightening.
Posts: 782 |
Not had any problems that I've noticed between services on my S3...
What about the nut behind the Wheel......
Em
