Morgan Aero 8
3 members (Montegue, ChrisConvertible, JMcL), 320 guests, and 73 robots.
+8Rich 70
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,877
Posts837,714
Bren #280281 10/06/15 04:14 PM
I have seen an early Aero where the drive shaft bolts are hanging out. Scary moment that was!!
My driveline shunt seems to be more noticeable when I returned from MOG 15. How accessable is it to check the drive shaft bolts
Bren #280571 11/06/15 08:49 PM
You will need to jack the car up at the back enough so you can slide yourself under the car, and then get a spanner to the bolts.
Morgan Plus 8 Speedster
2015 Defender 90 - Twisted/Bowler Mix
Hellfinger,
Many thanks, I am hoping this is the problem.
Bren #281237 14/06/15 03:00 PM
I have been told by the factory it's worth checking every 500/1000 miles depending how much stick you give the car I guess wink it's supposed to be one of the main things to check every service but dealers don't seem to know about this ?
Bren #281262 14/06/15 05:09 PM
I do check the drive shaft bolts at the annual service, but have never found any loose over the 7 years and 40,000km I've done with the car.
Cheers
Philip
1985 Plus 8 four seater
Malone F1000 - track car
Bren #281420 15/06/15 11:48 AM
I think the factory make things up as they go along,its the first time ive heard of checking every 500 mls.Mine are loctited not that it means very much.
Em
Bren #281436 15/06/15 02:41 PM
If a bolt/nut needs tightening after 500 miles then there is a major issue with design.
Such nuts should have a locking mechanism
Nyloc/lock washer/threadlock/pin/lockwire.
I find it alarming that the factory reccomends checks that often and not upgrade to make the design safer.
Ok...I have a trad and periodically check nuts/ bolts in some areas such as rear axle u- bolts etc.but not found any slackening to date.
The regular greasing that is advisable on the suspension etc is acceptable and allows a quick undercar check at the same time but driveshaft bolts/nuts at that frequency? A bit frightening.
Bren #281456 15/06/15 03:52 PM
Not had any problems that I've noticed between services on my S3...
Bren #281498 15/06/15 06:35 PM
What about the nut behind the Wheel......
Em
