Morgan Aero 8
1 members (BertL), 248 guests, and 41 robots.
+8Rich 95
John V6 52
Topics49,897
Posts838,017
#280521 11/06/15 03:39 PM
Rudolf Offline OP
Just returned from my first ride of the year( finally a combination of good weather and time).During parking Tango in the garage I spotted some oil on the floor.Oil is dripping from the splitter and the protection screen in front of the small cooler.This on the left side of the car centre( looking fwd).Some wet stains in the LH wheel bay,but does not look like the leak comes from that area.
Any suggestions where to look at before starting to strip the front?
Thanks for your help.
Rudolf.
Morgan Aero8 S4 «Tango»
Fisker Ocean
Harley Davidson Livewire
BMW R100/7 , R100R
Moto Guzzi 254
Rudolf #280532 11/06/15 04:32 PM
sure it is oil?
There is an oil cooler right in front of the air con, in front of the rad, the unions are on the near side i think.
There is also a gear box cooler up in a wheel area as well i think, air is drawn from the splitter area.
This i find useful.
http://www.aero-racing.co.uk/partsbooks/supersports/main_menu.htm
Rudolf #280539 11/06/15 05:33 PM
I may be way off the mark but I had a similar problem on S1 and ended up as a leaking pipe on the steering pump, with the oil tracking across the underneath to the other side of the car! Not sure if the S4 has the same problem?
15 Weissman GT5
11 Aero8 SS
21 Q7
23 RR
24 Def'r 130
1960 XK150 DHC
1970 E-type
2024 Huracan Tech
Rudolf #280554 11/06/15 07:24 PM
Rudolf Offline OP
Thank you Mark and Taffy.
I think it is oil.It looks like it is coming from the connection side of the small cooler(auto box cooler?).But it might be as Taffy says,the oil is coming from another place.
Hopefully I have some more time tomorrow to assess the problem.
Rudolf.
Fisker Ocean
BMW R100/7 , R100R
Moto Guzzi 254
Rudolf #280729 12/06/15 01:55 PM
Have a look at this thread:
http://www.talkmorgan.com/ubbthreads.php/topics/266734/Aero_SuperSports_What_Is_Leaki#Post266734
I had the hose tightened and gearbox oil topped up but it started leaking again on our last drive, which was fortunately to the Morgan factory! Apparently this is a common problem - the metal the hose sits over corrodes (inside the hose) and the part (not confident which part) needs replacement at around £500. Sounds like a weakness Morgan or we should address as nothing like this should fail in such a short time.
Current: Aero SuperSports
Previous: Aero 8 S3
Want: Aero 8 GTN
Rudolf #280741 12/06/15 03:35 PM
Rudolf Offline OP
Thanks Stephen.
That might be the problem.Had not time today to jack the car.Will find some time during the weekend.
Rudolf.
Fisker Ocean
BMW R100/7 , R100R
Moto Guzzi 254
Rudolf #281485 15/06/15 05:55 PM
Rudolf Offline OP
Found it after removing the splitter and the grille.Just an ordinary puncture of the gearbox oil cooler evil
Now I have to try to get it repaired or replaced here in Sweden. P/N is 52-10328-01 from Setrab oilcoolers ( made in Sweden).
Is there somebody here that have instructions available where and how to check and refill the gearbox oil.Also the oil spec is very welcome.
No dealer here within 350 km.
Rudolf.
Fisker Ocean
BMW R100/7 , R100R
Moto Guzzi 254
Rudolf #281496 15/06/15 06:31 PM
Rudolf.Ring the factory and ask to speak to Mark Baldwin tell them your ringing from Sweden so they wont fob you off.What he doesent know about any model is not worth mentioning always very helpfull and a top bloke.
Good luck Em
Rudolf #293008 01/08/15 05:15 PM
Rudolf Offline OP
What started with the oil leak repair,ended up with a full service.Replaced most fluids.Cleaned the ITG airfilter.Cleaned the tub after removing the wings and front.Had to remove some surface corossion.
Replaced all gearbox oil and filter( is the whole sump!) according instructions from the web for a BMW E70 N62 B48 engine.Today I was able to start the engine to fill the gearbox with engine running.I ended up with 8.1 liters of oil.
Anybody knows if this is a normal figure.I guess it is since I was not able to fill more,but I could not find an official figure.According the car material shop,the X5 needs 11 liters.
Btw,I have drilled a hole in the driver side footwell to get access to the fill plug.Otherwise I was still laying under my car to get the fill plug out.
Rudolf.
Fisker Ocean
BMW R100/7 , R100R
Moto Guzzi 254
Rudolf #293981 04/08/15 08:24 PM
Mr Fezza
Mr Fezza
Glad tango is all sorted smile
Check with the factory on oil capacity - as said before Mark Baldwin is the man - 5 mins of his time saves a lot of worry for you..
Maxxed out!
