0 members (),
319
Topics49,897
Posts838,017
Posts: 318 |
Just returned from my first ride of the year( finally a combination of good weather and time).During parking Tango in the garage I spotted some oil on the floor.Oil is dripping from the splitter and the protection screen in front of the small cooler.This on the left side of the car centre( looking fwd).Some wet stains in the LH wheel bay,but does not look like the leak comes from that area. Any suggestions where to look at before starting to strip the front?
Thanks for your help. Rudolf.
Morgan Aero8 S4 «Tango» Fisker Ocean Harley Davidson Livewire BMW R100/7 , R100R Moto Guzzi 254
Posts: 336 |
sure it is oil? There is an oil cooler right in front of the air con, in front of the rad, the unions are on the near side i think. There is also a gear box cooler up in a wheel area as well i think, air is drawn from the splitter area. This i find useful. http://www.aero-racing.co.uk/partsbooks/supersports/main_menu.htm
Posts: 378 |
I may be way off the mark but I had a similar problem on S1 and ended up as a leaking pipe on the steering pump, with the oil tracking across the underneath to the other side of the car! Not sure if the S4 has the same problem?
15 Weissman GT5 11 Aero8 SS 21 Q7 23 RR 24 Def'r 130 1960 XK150 DHC 1970 E-type 2024 Huracan Tech
Posts: 318 |
Thank you Mark and Taffy. I think it is oil.It looks like it is coming from the connection side of the small cooler(auto box cooler?).But it might be as Taffy says,the oil is coming from another place. Hopefully I have some more time tomorrow to assess the problem.
Rudolf.
Posts: 123 |
Have a look at this thread: http://www.talkmorgan.com/ubbthreads.php/topics/266734/Aero_SuperSports_What_Is_Leaki#Post266734I had the hose tightened and gearbox oil topped up but it started leaking again on our last drive, which was fortunately to the Morgan factory! Apparently this is a common problem - the metal the hose sits over corrodes (inside the hose) and the part (not confident which part) needs replacement at around £500. Sounds like a weakness Morgan or we should address as nothing like this should fail in such a short time.
Current: Aero SuperSports Previous: Aero 8 S3 Want: Aero 8 GTN
Posts: 318 |
Thanks Stephen.
That might be the problem.Had not time today to jack the car.Will find some time during the weekend.
Rudolf.
Posts: 318 |
Found it after removing the splitter and the grille.Just an ordinary puncture of the gearbox oil cooler  Now I have to try to get it repaired or replaced here in Sweden. P/N is 52-10328-01 from Setrab oilcoolers ( made in Sweden). Is there somebody here that have instructions available where and how to check and refill the gearbox oil.Also the oil spec is very welcome. No dealer here within 350 km. Rudolf.
Posts: 2,439 Likes: 71
Posts: 2,439 Likes: 71 |
Rudolf.Ring the factory and ask to speak to Mark Baldwin tell them your ringing from Sweden so they wont fob you off.What he doesent know about any model is not worth mentioning always very helpfull and a top bloke.
Good luck Em
Posts: 318 |
What started with the oil leak repair,ended up with a full service.Replaced most fluids.Cleaned the ITG airfilter.Cleaned the tub after removing the wings and front.Had to remove some surface corossion. Replaced all gearbox oil and filter( is the whole sump!) according instructions from the web for a BMW E70 N62 B48 engine.Today I was able to start the engine to fill the gearbox with engine running.I ended up with 8.1 liters of oil. Anybody knows if this is a normal figure.I guess it is since I was not able to fill more,but I could not find an official figure.According the car material shop,the X5 needs 11 liters. Btw,I have drilled a hole in the driver side footwell to get access to the fill plug.Otherwise I was still laying under my car to get the fill plug out.
Rudolf.
Mr Fezza Talk Morgan Expert
Posts: 2,825 |
Glad tango is all sorted Check with the factory on oil capacity - as said before Mark Baldwin is the man - 5 mins of his time saves a lot of worry for you..
-------------- Maxxed out!
