7 members (sewin, Morganmike, Joske Vermeule, Adam12, +8Rich, BobtheTrain, HawkMog),
311
43
New
Topics48,365
Posts813,374
Members9,215
Posts: 5,181 Likes: 2
Posts: 5,181 Likes: 2 |
Posts: 26,763 Likes: 425
Posts: 26,763 Likes: 425 |
+2. My 1994 Zetec 4/4 didn't knock but it had been remapped
Posts: 5,016 Likes: 3
Posts: 5,016 Likes: 3 |
Different sub-subject:
Does the +4 and the 4/4 (2011 production, 1600 Sigma engine) have the same gearbox? My 4/4 misses lots of power to use the higher gears in a sporty way. I did some 3000km last two weeks and drove some great Alpine roads including the Col de la Bonnette and the Passo Stelvio. I would have preferred a different selection of gears (and better weather conditions).
Posts: 14,009 |
The answer is yes they do. I had the same problem with my 2010 4/4 Sport. 5th gear was not very useable. I changed my differential for the Competition 4.11:1 version which made a significant difference.
Posts: 14,723 Likes: 149
Posts: 14,723 Likes: 149 |
John. Do you remember what the standard ratio is? What sort of costs are involved in a swap? And did you re-calibrate the speedo?
Posts: 14,009 |
Peter, the standard ratio was 3.73:1. I paid Mike Duncan around £1,000 for the job as far as I can remember. Ben Duncan calculated the adjusted speedo code for me. It was fairly accurate but I ended up tweaking it until it was nearly spot on.
Posts: 7,342 Likes: 91
Posts: 7,342 Likes: 91 |
Would it be possible to swap the gearbox of a 2011 4/4 and replace it with the Mazda box which is assembled on the later 4/4s? One could benefit of the more reasonable gear ratios. And, would it cost more tha changing the diff if considering a used Mazda gearbox?
I thought the 2011 4/4 used the Mazda box.
Posts: 5,210 |
Peter, I maybe wrong but I think the Mazda box was used from 2012.
I thought the 2011 4/4 used the Mazda box. Mine (6/2011) does not have the Mazda box.
