1 members (BHV), 284 guests, and 43 robots.
+8Rich 95
John V6 49
Posts837,992
rockabilly john
#283080 23/06/15 01:03 PM
Sinbad Offline OP
Can anyone out there with an early (pre-war) 4/4 help me please. I am having a new hood made by a local trimmer and all is set to go ahead except we have no idea about the hood frame webbing.
How wide is it?
How is it attached to the frame hoops?
Is it fastened to the body at the rear, if so how?
What is the distance between the hoops with the frame in the raised position?
What keeps the frame up when the hood is on?
Can you recommended a webbing supplier?
Photographs and/or drawings and measurements would be a great help
Many thanks
1967 Plus 4 Drophead coupe with a TR4a engine
Sinbad #283151 23/06/15 07:34 PM
Sinbad
Can't answer your questions directly but be careful. I doubt any car has survived 70 years in the original state.
I would rather think the 1972 4/4 I had was rather similar, and I replaced the webbing on that. The webbing was fixed at the rear of the car.
I used webbing from this firm.
Woolies hood webbing
Depending on colour of car and or hooding, I'd be tempted to use beige or fawn, the black takes a very long time to fade and those colours are nearer what one imagines original webbing to have faded to.
The 'what keeps the hoops + webbing up' is simple, the hood. The forward-most hoop is held up as is it cannot go further forward because of the webbing and cannot go backwards as the hood restrains it. If you have the hoops in place, hinge it to about the right place, then hinge it back. The hood would have to have a huge bulge for it to go backwards; so it doesn't.
If your trimmer has made a hood for any sports car, he'd know all that though.
Last edited by Martyn Culling; 23/06/15 09:18 PM. Reason: corrected display name on web link
Sinbad Offline OP
Martin
Thank you so much for your reply. I have had great difficulty getting information due to lack of published photographs or other forms of reference. The information is a great help. Thank you
Regards
Cyril
Sinbad #283556 25/06/15 01:26 PM
Sinbad
Was there any such thing as a standard hood prewar ?
Most if not all purchased their car and then went to the
hood provider of their choice . Many where never fitted with hoods.
regards Chris
Sinbad #283587 25/06/15 02:49 PM
Posting Desperado
Posting Desperado
How wide is it?
Approx 2.5in
You should have 3 hoops this depends on how many sections your hood is made of hoop for the rear two sections
ie. from rear body to height is the rear window section , then up and approx to highest point somewhere above front of axel followed to approx rear of doors .
It is measured that the hoops are inline with the hood stiching there are two lengths of webbing one above each seat . You need a loop stiching in each one where they touch the hood seams and should be tight when pulled ( that is 6 , 3 for each side ) so the hood bars can slip through them . The webbing can be fitted to the carpet above the petrol tank pull the topof the carpet off and stich the webbing on once you are 100% sure and when pulled up should be tight . With the webbing in the middle of the seats, if you let go then it all falls back to the rear of the car . Get the hood bars powder coated 1st . Also make sure you know the correct way to fit them in the sides put a paper sticker on each bar at each side .
The frame is kept up by the hood being fastened to the screen .
Woolies ( I&C Woolstenholmes Ltd) Whitley Way Northfields Industrial Estate MARKET DEEPING PETERBROUGH PE6 8AR 01778 341847
www.woolies-trim.co.uk
info@woolies-trim.co.uk
Now go and have a look at other mogs take your camera and a jotter , pencil and rubber and a tape measure .
I have just spent a good while watching a trimmer doing mine and he had other cars in two 1920s Alvis they come in with nothing and they build them from scratch frames hoods etc . I really can not help myself I have to have a look at everything I see people do .
Many thanks
