0 members (), 285 guests, and 44 robots.
+8Rich 86
by stumog - 26/08/26 10:24 AM
Topics49,844
Posts837,360
#291385 26/07/15 12:09 PM
P964 Offline OP
As mentioned in another thread we recently had a windscreen self destruct.
So i have taken to ignore morgan for parts and to do it myself.
Removing the old screens was harder than it seemed. They are well stuck and only let go after a judicious application of brute force.
I found a plastics company who were able to cut replacements using the unbroken screen as template. Left and right are the same and are not curved.
I decided to use 3 mm polycarbonate instead of the 4.5mm acrylic
The sealing of this thinner material and issues with using silicone with the polycarbonate provided some head scratching but eventually sorted it. Fingers crossed its weather tight.
After seeing Callums DIY write up, i have done the same but at 20 mb i will need to find somewhere to put it!
Before and after pictures
ZK-Mog
ZK-Mog
Great job
nice work - looking forward to your diy write up as I am not far behind you on this job
Lexan is used for bullet proof car windows (as a laminate) and for headlights
It makes you wonder why they chose Acrylic over Polycarbonate given the vast inherent strength differences, I wonder if it was down to re-polish ability?
Mark - No Longer driving
Check this thread for place to put your writeup.
http://www.talkmorgan.com/ubbthreads.php/topics/286426/1
2013 M3W
2025 Plus Four
Looks like a very neat job especially the seal.
I would say that replacing the screen can be a bit of a fiddle but if one is going to all that effort it might be better to replace with a Fairbourne Screen?
It has transformed the driving experience in my car. It is now like driving a normal sports car.I think it also improves the look of the car too. They now make a lower screen with a central bracket if you still want some more wind in your face.
I would post some pictures but I cant for the life of me work out how to post pictures on this site!
Will get round to it someday but in the meantime here's a link to Fairbourne.
http://www.fairbournecarriages.com/index...0&Itemid=65
M3W 'The Mapmog' Built June 2015
Love the Fairbourne screen! Looks very period and simply works!!
If I had a Three wheeler /when I buy another I would fit one!
Neil
P964 Offline OP
Hi Matt
The Morgan Manual website is still under construction, so i have put the "What i did file" in dropbox. See url below
A signup popup box can just be closed. The file is big at 20MB so takes a little time to load.
Not been able to take the screen for a drive yet, work and rain conspire against us for the moment.
Write up is a bit of a ramble but hopefully there are some gems to be found.
https://www.dropbox.com/s/z07cqeqoo9b9i7s/Removal%20of%20Windscreen.ppt?dl=0
Next i want to find a place to put the registration label. Previously was on inside of passenger screen but i think it is intrusive and ugly there. ( unfortunately that is the mandated position on windscreen for motor cars in NZ). Have got a motorcycle label holder, just need to find the perfect place to bolt it. In my opinion, as we have no wipers so we cant have a windscreen so the car mandate doesnt apply?? !! Most likely will put on rear numberplate along with Warrant of Fitness a la motorcycle.
1 member likes this: Russ
ZK-Mog
ZK-Mog
Very useful write up. I too am wondering where to put the warrant and rego, especially with my small screens. I've seen the tubular motorbike ones on Trademe and might get a couple just in case I go that way
Great writeup. I was in the area adjusting my steering column and don't recall seeing a "drip shield". I can recall seeing the lower tabs on the windscreen though. Mine is a 2013. I'm curious if Morgan either forgot to install it, or something in the design changed.
Thanks for sharing!
2013 M3W
2025 Plus Four
