2 members (gmcn, Pigiron),
190
52
Topics49,843
Posts837,336
Posts: 38 |
I noticed that some of the 3 wheelers have a lighter port. Has anyone hooked up inverters for charging electronics? How many watts can that port handle?
Also has anyone done any additions or mods to support multiple ports?
Posts: 1,370 Likes: 11
Posts: 1,370 Likes: 11 |
Open the fuse panel to see the wattage on that.
Posts: 1,737 Likes: 55
Posts: 1,737 Likes: 55 |
Fuse 18, Intercom & 12V Power Skt: 15A (on my 2012 3 wheeler).
Andy
Posts: 303 |
If your going to fit big inverter I would come of battery with a thick cable
Posts: 2,822 Likes: 155
Posts: 2,822 Likes: 155 |
If I remember correctly you have a a total of 38A available from the alternator to run everything including the fuel pump, injection, ignition etc. It's easy enough to either add a fused cable and socket direct to the battery or there should be one or more unused fuses in the fuse box.
Posts: 582 |
Run a separate power supply from the terminal in the right front under the oil tank. You can set this up with a relay and wire a switch to the cockpit and have your inverter plugin anywhere you want it.
